Latest post 01-31-2012 6:16 PM by Stoobietoo. 3 replies.
Page 1 of 1 (4 items)
  • 01-29-2012 12:53 PM
    Help needed with IR eye wiring for Beomedia 1 (resolved diagram attached)
    I need some help wiring up an IR eye for my Beomedia 1. I have done a search and, whilst I can find wiring diagrams, none match what I need. I have a non HD Beovison 5, which unfortunately cannot control the BM1.
    I have a spare eye from a project and it is similar to the top one in my diagram below. It's from an unused Beolink Passive - so will it work with my BM1 if wired correctly? I saw some info that not all B&O IR eyes are the same!
    Mine has the connector block with 5 wires. I need to wire it to a mini jack as per the second diagram, but that is showing connector block with 8 wires so I'm confused.
    Can anyone help.
    Any help would be appreciated.
    Stoobie
    PS I enjoy drawing on my computer so the pic below is done by me.
    (See bottom message for correct wiring diagram)
  • 01-29-2012 1:57 PM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: Help needed with IR eye wiring for Beomedia 1
  • 01-29-2012 2:12 PM In reply to
    That looks very promising.
    I'll give that a try and let you know
    Stoobie
  • 01-31-2012 6:16 PM In reply to
    Guy1680:
    Unfortunately that did not work. However I did a bit of trial and error and got it working. Here is the updated diagram for the BM1/ IR eye wiring.
    Thanks for everyone's help
    Stoobie
