I have a problem with my beosound 9000; it is not responding to anything; not to remote commands, not to the buttons on the unit itself.
Some background:
I had the beosound connected to a bv8-40. The BV8-40 has been out for repair (long story...). During the repair time the beosound 9000 has been unplugged. After reconnecting the beosound 9000 to the bv8-40 the unit started to work. But the strange thing was that the beosound 9000 did turn off after a couple of minutes, but did not ask for the pin code.
Because I did not get it to work, I have disconnected the beosound 9000 from the bv8-40 and connected speakers directly to the beosound 9000. Now I do not get it to work at all! Tried to disconnect it from the mains for some time, but also no luck.....
Another strange thing; every now and then (every 3-5 minutes) the unit makes a bit of sound; the led blinks and the connected speakers also "click".
Any help would be greatly appreciated!!!!
Regards,
Dennis
