The metallwork will fit just fine.
The plastic underside to the CD lid will need to be transferred from the 9500 panel to the 9000 panel to retain activation of the clamping mechanism. It is held on with double sided tape so not too much of a problem.
Yes, I have done it but only as an exercise to see if it worked.
