Latest post 01-26-2012 1:30 PM by Johan. 2 replies.
Page 1 of 1 (3 items)
  • 01-26-2012 12:02 PM
    • Johan
    • Not Ranked
    • Joined on 12-28-2011
    • Sweden
    • Posts 21
    • Gold Member
    Fit BC9000 panel on BC9500?
    Hello!
    I was thinking that maybe one could take the brushed alu panel from a Beocenter 9000 and replace the glossy panel on a Beocenter 9500.
    Are they the same size? Would it be possible? Has anyone done it?
    Thanks!
    /  Johan
  • 01-26-2012 1:24 PM In reply to
    Re: Fit BC9000 panel on BC9500?
    The metallwork will  fit just fine.
    The plastic underside to the CD lid will need to be transferred from the 9500 panel to the 9000 panel to retain activation of the clamping mechanism. It is held on with double sided tape so not too much of a problem.
    Yes, I have done it but only as an exercise to see if it worked.
    Regards Graham
  • 01-26-2012 1:30 PM In reply to
    • Johan
    • Not Ranked
    • Sweden
    • Posts 21
    • Gold Member
    Awesome, thanks!
