Latest post 02-01-2012 4:33 AM by LC. 6 replies.
Page 1 of 1 (7 items)
  • 01-24-2012 7:54 AM
    • Iceman
    • Not Ranked
    • Joined on 03-23-2008
    • Posts 4
    Playstation 3 problem
    Hi
    I have Playstation 3 connected to my bv7-32 mkI using ypbpr. Last weekend I accidentally reset the PS3, and now I only see a black screen on the tv.
    I know all outputs on the PS3 is working. I have a picure both when connecting it using SCART, hdmi-DVI. And when i try to connect the ypbpr- green to the camera port on the side of the tv I also have a picture.
    Now i am running out of ideas how to make it work.
    Can anyone help?
    Regards
    Jesper
    Filed under: , ,
  • 01-24-2012 4:06 PM In reply to
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    Re: Playstation 3 problem
    Try turning on the PS3 by holding the power button pressed, until you hear a second "chime". This will force the PS3 to send out picture on all connections. I don't know if this will work in your situation, as you describe having picture on the other connections, but it's worth a try.
  • 01-25-2012 6:47 AM In reply to
    • Iceman
    • Not Ranked
    • Posts 4
    Thanks for the reply!
    Sadly this did not work either.
    I'm starting to believe that the tv needs a repairSad
  • 01-27-2012 4:02 PM In reply to
    • LC
    • Not Ranked
    • Joined on 11-23-2010
    • London
    • Posts 24
    • Silver Member
    This is a problem i have experienced many times before with early beovision 7's and the component input.
    You need to connect your ps3 to another tv and set the output to be component 720p. Save it and then put it back in your b&o and it should work
    Louis
  • 01-31-2012 4:14 AM In reply to
    • Iceman
    • Not Ranked
    • Posts 4
    Hi Louis
    Thank you for replying.
    I will try this although I don't see why this would help.
    I'll return with the results.
    Jesper
  • 01-31-2012 5:28 PM In reply to
    • Iceman
    • Not Ranked
    • Posts 4
    SOLVED
    Apparently the tv doesn't support resolutions below 720p on ypbpr??? I wasn't aware of that.
    As i didn't have another tv at hand, I had to set the ps3 to output 720p on ypbpr in the dark.
    Thank you Louis!
    Jesper
  • 02-01-2012 4:33 AM In reply to
    • LC
    • Not Ranked
    • London
    • Posts 24
    • Silver Member
    No problem, glad i could help
    That has baffled me for hours in the past!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
