Latest post 02-22-2012 5:15 AM by Chris. 13 replies.
Page 1 of 1 (14 items)
  • 01-18-2012 8:32 AM
    • Chris
    • Top 500 Contributor
    • Joined on 05-09-2010
    • Last of the Summer Wine Country, Yorkshire, UK
    • Posts 195
    • Gold Member
    Bose XML File
    I remember seeing a while ago an XML file for Bose remote control. All I am wanting is Volume Up/ Down. Mute and possibly On/ Off.
    Thanks!
    Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
  • 01-18-2012 8:40 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Dear Mr....
    Thank you for contacting BOSE®.
    Unfortunately we do not have the HEX information for the CineMate systems available, however many universal remotes have a learning facility built in to them and will allow a customer to gain the necessary information from a remote in this way. The only buttons on the CineMate remote you would need to learn will be on/off, volume up, volume down and mute and the rest of the functions are used as part of its universal ability.
    Should you have any further questions then please feel free to contact us on 0870 741 4500 or by replying to this email.
    Please note that our Aftersales/Technical support opening hours are from 9am until 5pm, Monday to Friday
    Kind Regards,
    Dan Usher
    Technical Support Analyst
    Bose Ltd
    1 Ambley Green
    Gillingham Business Park
    Gillingham
    Kent
    ME8 0NJ
    Tel: 0870-741-4500
    Fax: 0870-741-4545
  • 01-18-2012 10:10 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Dear Mr Harrison
    Thank you for your reply.
    I have spoken to the development department to request the required information and have been provided with the following HEX information for the CineMate®:
    On Off
    0000 006b 0022 0000 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0041 0015 0041 0015 0015 0015 0041 0015 00ac
    Mute
    0000 006b 0022 0000 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
    Volume Down
    0000 006b 0000 0022 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
    Volume Up
    0000 006b 0000 0022 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
    I hope this helps.
    Kind Regards,
    Dan Usher
    Bose Ltd
  • 01-18-2012 4:01 PM In reply to
    Re: Bose XML File
    Chris, just bring your Bose remote and Beo6 into the store and I will do it for you, takes about 10 minutes!
    Call ahead though to make sure I am in.
    Martin (B & O Newcastle)
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
  • 01-18-2012 5:16 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Martin, I have sent you an email. Unfortunately I live in West Yorkshire however if you could create a file I would be willing to post you my Bose Remote control if you like and send it back to me.
    Thanks, Chris
  • 01-19-2012 4:37 PM In reply to
    Re: Bose XML File
    Chris,
    I have converted your Pronto HEX codes and made an XML file which is HERE
    Regards Keith....
  • 01-20-2012 7:11 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Hi Keith, Thanks very much for creating this file. Unfortunately it doesn't seem to work. I will get in touch with Bose - maybe they have provided the incorrect HEX codes.
    Also another question. I have a Beosound 8 and it will not work with the supported BS8 file on version 4.11 - It does however work with a Radio/ CD function on the Beosound3000 - play, pause, volume up/down etc. Is this a common fault?
  • 01-20-2012 5:23 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Mute: 0x01
    Device Code: 186.160 (0xBA.0xA0) Function: 1 (0x01)
    0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
    Volume Down: 0x02
    Device Code: 186.160 (0xBA.0xA0) Function: 2 (0x02)
    0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
    Volume Up: 0x03
    Device Code: 186.160 (0xBA.0xA0) Function: 3 (0x03)
    0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
    Power: 0x4C
    Device Code: 186.160 (0xBA.0xA0) Function: 76 (0x4C)
    0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0689
    Hi Keith, Can you have a go at these? Thanks :-D
  • 01-21-2012 8:33 AM In reply to
    Re: Bose XML File
    I have created a new XML file with exactly the same filename at the previous posting link where you downloaded before.
    These codes look much more positive and decode to standard NEC 32 bit protocol and are much more likely to be correct.
    Regards Keith....
  • 01-21-2012 8:46 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Do you have a link to the file? Chris
  • 01-21-2012 9:20 AM In reply to
    Re: Bose XML File
    Chris:
    Chris,
    Can you please read my previous wording again..
    The link you used last time in my previous posting is the link to use. The file has exactly the same filename as before and is downloaded from the same link.
    Regards Keith....
  • 01-23-2012 7:59 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Apologies Keith, it had been a long day at work!
    I am testing the file and it seem to be controlling my Beosound 8 and not the Bose. It's very strange. I could post you the remote if you like?
    Thanks again, Chris
  • 01-25-2012 3:57 PM In reply to
    Re: Bose XML File
    Chris,
    If you would like to send me your remote I will check it out for you. I will PM you.
    Regards Keith....
  • 02-22-2012 5:15 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Bose XML File
    Martin, You are a credit to Beoworld! The file works perfectly and is very easy to control on the remote.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
