1st March February 2012
Latest post 02-22-2012 5:15 AM by Chris. 13 replies.
01-18-2012 8:32 AM
Chris
![](/utility/anonymous.gif)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 05-09-2010
- Last of the Summer Wine Country, Yorkshire, UK
- Posts 195
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
I remember seeing a while ago an XML file for Bose remote control. All I am wanting is Volume Up/ Down. Mute and possibly On/ Off.
Thanks!
Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
Chris
- Posts 195
Dear Mr....
Thank you for contacting BOSE®.
Unfortunately we do not have the HEX information for the CineMate systems available, however many universal remotes have a learning facility built in to them and will allow a customer to gain the necessary information from a remote in this way. The only buttons on the CineMate remote you would need to learn will be on/off, volume up, volume down and mute and the rest of the functions are used as part of its universal ability.
Should you have any further questions then please feel free to contact us on 0870 741 4500 or by replying to this email. Please note that our Aftersales/Technical support opening hours are from 9am until 5pm, Monday to Friday
Kind Regards,
Dan Usher Technical Support Analyst
Bose Ltd 1 Ambley Green Gillingham Business Park Gillingham Kent ME8 0NJ
Tel: 0870-741-4500 Fax: 0870-741-4545
Chris
- Posts 195
Dear Mr Harrison
Thank you for your reply.
I have spoken to the development department to request the required information and have been provided with the following HEX information for the CineMate®:
On Off
0000 006b 0022 0000 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0041 0015 0041 0015 0015 0015 0041 0015 00ac
Mute
0000 006b 0022 0000 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
Volume Down
0000 006b 0000 0022 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
Volume Up
0000 006b 0000 0022 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
I hope this helps.
Kind Regards,
Bose Ltd
MartinW
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.57.21/avatar.jpg)
- Joined on 11-01-2007
- Posts 84
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Chris, just bring your Bose remote and Beo6 into the store and I will do it for you, takes about 10 minutes!Call ahead though to make sure I am in.Martin (B & O Newcastle)
BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
Chris
- Posts 195
Martin, I have sent you an email. Unfortunately I live in West Yorkshire however if you could create a file I would be willing to post you my Bose Remote control if you like and send it back to me.
Thanks, Chris
Chris
- Posts 195
Hi Keith, Thanks very much for creating this file. Unfortunately it doesn't seem to work. I will get in touch with Bose - maybe they have provided the incorrect HEX codes.
Also another question. I have a Beosound 8 and it will not work with the supported BS8 file on version 4.11 - It does however work with a Radio/ CD function on the Beosound3000 - play, pause, volume up/down etc. Is this a common fault?
Chris
- Posts 195
Mute: 0x01 Device Code: 186.160 (0xBA.0xA0) Function: 1 (0x01) 0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Volume Down: 0x02 Device Code: 186.160 (0xBA.0xA0) Function: 2 (0x02) 0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Volume Up: 0x03 Device Code: 186.160 (0xBA.0xA0) Function: 3 (0x03) 0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Power: 0x4C Device Code: 186.160 (0xBA.0xA0) Function: 76 (0x4C) 0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0689
Hi Keith, Can you have a go at these? Thanks :-D
Chris
- Posts 195
Do you have a link to the file? Chris
Keith Saunders
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.92/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Chris:
Chris,
Can you please read my previous wording again..
The link you used last time in my previous posting is the link to use. The file has exactly the same filename as before and is downloaded from the same link.
Chris
- Posts 195
Apologies Keith, it had been a long day at work!
I am testing the file and it seem to be controlling my Beosound 8 and not the Bose. It's very strange. I could post you the remote if you like?
Thanks again, Chris
Chris
- Posts 195
Martin, You are a credit to Beoworld! The file works perfectly and is very easy to control on the remote.
Page 1 of 1 (14 items)
