Latest post 01-19-2012 4:40 PM by Stoobietoo. 4 replies.
Page 1 of 1 (5 items)
  • 01-17-2012 3:57 AM
    Beo 5 and Samsung 3d plasma - I need help !
    I am very happy that I have just joined this forum of the B&O users and fans  . I have just purchased a beo5 for my B&O Beosound 9000.
    I would be so grateful if Keith, that is doing such a wonderful job here, could help me in programming my Beo5 for the 3rd party Samsung 3D plasma TV. I found some codes for it on the lintronic site and I  post them below:
    723 007 007 017 238 000 000 0
    723 007 007 004 251 000 000  1
    723 007 007 005 250 000 000  2
    723 007 007 006 249 000 000  3
    723 007 007 159 096 000 000  3d
    723 007 007 008 247 000 000  4
    723 007 007 009 246 000 000  5
    723 007 007 010 245 000 000  6
    723 007 007 012 243 000 000  7
    723 007 007 013 242 000 000  8
    723 007 007 014 241 000 000  9
    723 007 007 039 216 000 000  ad
    723 007 007 022 233 000 000  blue
    723 007 007 107 148 000 000  ch list
    723 007 007 121 134 000 000  content
    723 007 007 097 158 000 000  down
    723 007 007 045 210 000 000  exit
    723 007 007 072 183 000 000  forward
    723 007 007 020 235 000 000  green
    723 007 007 079 176 000 000  guide
    723 007 007 031 224 000 000  info
    723 007 007 147 108 000 000  internet.tv
    723 007 007 101 154 000 000  left
    723 007 007 140 115 000 000  media.p
    723 007 007 026 229 000 000  menu
    723 007 007 015 240 000 000  mute
    723 007 007 104 151 000 000  ok
    723 007 007 062 193 000 000  p.size
    723 007 007 074 181 000 000  pause
    723 007 007 071 184 000 000  play
    723 007 007 002 253 000 000  power
    723 007 007 019 236 000 000  pre-ch
    723 007 007 016 239 000 000  prog down
    723 007 007 018 237 000 000  prog up
    723 007 007 073 182 000 000  record
    723 007 007 108 147 000 000  red
    723 007 007 088 167 000 000  return
    723 007 007 069 186 000 000  rewind
    723 007 007 098 157 000 000  right
    723 007 007 001 254 000 000  source
    723 007 007 070 185 000 000  stop
    723 007 007 037 218 000 000  subt.
    723 007 007 044 211 000 000  text
    723 007 007 075 180 000 000  tools
    723 007 007 096 159 000 000  up
    723 007 007 011 244 000 000  volume down
    723 007 007 007 248 000 000  volume up
    723 007 007 021 234 000 000  yellow
    Thank you so much Keith in advance !!!
    Best regards,
    Stefan
    Filed under:
  • 01-17-2012 1:17 PM In reply to
    Re: Beo 5 and Samsung 3d plasma - I need help !
    A Very Warm Welcome to Beoworld..
    The Protocol used by these Samsung Plasma TV's is a modified NEC protocol which repeats the signal twice for every button press.
    Because of the number of different combinations of remote commands for Samsung TV's I have made an XML for all the common commands
    The XML file HERE includes the common commands and the hard keys and digits are pre-assigned, so all you need to do is drag-n-drop without doing any modification.
    The XML file is contained in a ZIP file which should be extracted to C:\ and then it will automatically be placed in the correct directory of the B&O Configuration Tool.
    Let us all know how it works on your TV..
    Regards Keith....
  • 01-18-2012 9:30 AM In reply to
    Hello Keith,
    My Plasma Samsung works. You are the best Keith ! thank you so much !!!!
    I would like to ask you one more question ! I don't not know why sometimes when I make changes in my Beo5 with the ConfigTool the battery becomes empty instantly even it was fully charged overnight. I am just wonderring if there is a malfunction inside my Beo5 or... ?
    What should I do ?
    Many thanks in advance !!
  • 01-19-2012 4:17 PM In reply to
    Thank you for your feedback and I am pleased your Samsung Plasma is working.
    With regards to the Beo5 battery being empty, there could be many reasons for that.
    Whilst the Beo5 could have a fault is actually very unlikely to be the cause.
    The most likely causes of this type of problem are often cause when you have captured a 3rd party IR codes and made an XML file, but one or more of the codes is not quite correct and usually the last binary digit is left as a "1" meaning the transmitting diode is left on all the time.
    Also if you every press a button and the button stays triggered and you have to power down / reset the Beo5 then you have certainly got the problem I highlight above.
    Regards Keith....
  • 01-19-2012 4:40 PM In reply to
    mstsima:
    Do you mean this happens while you are changing the configurations connected to the PC rather than after everyday use on the mains charger?.
    When I used to program my BEO5 I would find that even though it was fully charged, if I connected to my PC and made a few changes, the battery would go flat very fast and I'd have to do a long recharge on the mains before I could re-connect to the PC and make any more changes. Even though it shows as "charging" while connected to the PC it seemed the battery depleted 10 times faster than it charged up. Even leaving overnight on the PC did not chare it enough, whereas an hour on the mains charger was enough.
    Things seem far better now that I'm using Config Tool 5.12 and it doesn't seem to deplete the battery so fast when I'm programming. I can try numerous updates before the battery depletes now.
    Stoobie.
