I have a Beomaster 3300, Beocord 3300 and Beogram CD3300 systems that I reconditioned to like-new condition, but I have a small issue. It is not a huge problem, but terribly annoying. My Terminal 3300 remote works fine, but the 9-voly battery will only last about 3 weeks whether I use it or not. I use the system about 3 nights a week in my bedroom. I turn it on, maybe change the FM station once or twice, then I turn it off later all using the remote. I make sure the remote is upright with nothing sitting on the buttons. At first I thought it might be bad batteries, so I've tried different types, brands and even stores where they were purchased. I have ohmed out the battery connector and it seems fine, no short or anything. Is this normal for the Terminal 3300? Do I need to buy batteries by the case? Like I said, this is not a major issue, but after a hard day at work, ice and snow outside, I'm cozy and bundled up in my bed and I reach over for the remote to listen to some old Motown music as I drift off to sleep and the &$#%@ remote won't work!!!
