Latest post 01-12-2012 2:21 AM by BeoIce. 1 replies.
Page 1 of 1 (2 items)
  • 01-11-2012 7:18 AM
    • BeoIce
    • Top 200 Contributor
    • Joined on 03-27-2007
    • Recklinghausen, Germany
    • Posts 281
    Beosound Century - mechanical problem moving clamper
    Hi folks,
    some month ago I bought a Beosound Century. When it arrived it was so dirty, I had to disassemble it completly to clean it. There was dirt in every space you can think of. After cleaning and reassembling it, I have a mechanical problem with the clamper lifting up or down. The problem in detail is, that the clamper moves up or down, but on half of it's way there is a noise like some plastic crackling. The movement stops for a part of a second and then goes on. I inspected everything that could interrupt soft moving, but I found nothing. All moving parts have been re-greased after cleaning, so this shouldn't be a problem.
    Does anybody have an idea what the problem might be ?
    Anything else, like the door mechanism works like a charm.
    Regards
    BeoSound 9000 MK III, BeoLab 6000, BeoLab 11, BeoCenter 2300, BeoSound Century, BeoVision MX4000/MX7000 & BeoCom 4
    Samsung UE40B7090, Samsung HT-WS1G, Technisat HD8-S, Sony PS3, Logitech PS3 IR-BT-Adapter & Lintronic TT455-RT-238
  • 01-12-2012 2:21 AM In reply to
    • BeoIce
    • Posts 281
    Re: Beosound Century - mechanical problem moving clamper
    No one who could assist ?
    Regards
