Latest post 01-10-2012 4:24 PM by mjmedlo. 6 replies.
Page 1 of 1 (7 items)
  • 01-06-2012 4:30 AM
    ML Gateway & Exchange of TV
    Hi
    Could anyone advise if I am having a change of TV, same model etc, is there any modifications needed to be made within the ML Gateway. I am hoping for a straight exchange, without any changes to the rest of the system......
    Thanks for any information givenSmile
  • 01-06-2012 12:03 PM In reply to
    Re: ML Gateway & Exchange of TV
    A Very Warm Welcome to Beoworld.
    You don't say what TV you are talking about, but all B&O Masterlink products to be accessed to/from the Gateway must meet minimum software revision levels to work.
    In short, the fact you are replacing the TV with the same model may or may not work depending on software revision level.
    Regards Keith....
  • 01-08-2012 1:44 PM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    The model I the tv will determine.
    It is relatively aimless to work the B&O program that accompanies the mlgw.
    You'll just have to identify your new tele in the B&O software.
    Good luck and congrats!
    I'm ready for something new that I actually want to buy!
  • 01-08-2012 2:36 PM In reply to
    Hi
    Thanks for the replies..
    Its a BV7-55 standard, latest model, being upgraded to a BV7-55 3D TV, so all SW is latest...
    I am hoping not to get a programmer in to interrogate the gateway if possible, just to swap over the TV's
    Is this workable>>
  • 01-08-2012 6:57 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    If you have a computer you can do this on the gateway.
    Its VERY simple.
  • 01-10-2012 3:35 PM In reply to
    If its easy, could you instruct me on how to do this, as I dont want the original guy back.....
    Thank you
  • 01-10-2012 4:24 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Sure thing. . .
    send me a PM so I will have a good email to get ahold of you!
