Latest post 01-11-2012 8:39 AM by Evan. 5 replies.
Page 1 of 1 (6 items)
  • 01-05-2012 4:06 PM
    preamp for beolab 8000
    Hi
    looking for a preamp to connect my beolab 8000.
    does anyone know this one:
    AMC AV81HTc-DD -Preamp
    any other suggestions? budget around 300-400$
    thanks
  • 01-07-2012 9:53 AM In reply to
    Re: preamp for beolab 8000
    orenhefetz:
    Hi
    thanks
    The AMC amp has no line level outputs, pay a little more and go for an Onkyo, for  550 USD you can get a TX-NR 708 or 709, these amps gives a lot of posibilities.
    For active speakers a line level output is a must.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-07-2012 10:17 AM In reply to
    thanks!
    i'm trying to avoid a Receiver. looking for a preamp. some of them have a line level output
  • 01-08-2012 10:51 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Orenhefetz,
    That AMC looks like a winner. I actually quite like it. Apert from that, have you thought of an NAD 1020? Those seem to be the go-to preamp and can be had in your price range. If you are looking for just enough to push a stereo config, consider the Onkyo TX-8050, fits you bill as well. I know its a receiver but you don't have to use it like one.
    FYI, "line level" is not what you are looking for, those are not volume controlled and will result in some frazzled 8000s. If you end up buying a receiver, a "Pre-out" would be the correct connection.
    Evan
  • 01-10-2012 2:24 PM In reply to
    thanks evan
    what do you say about the
    ROTEL RSP-960AX? 120$ on ebay
  • 01-11-2012 8:39 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    That looks like it would do a fine job. I can only fully recommend Rotel. They make products that are very hard to fault. If you can get one with a remote for that price I think you would be in for a good deal.
    Evan
