Latest post 01-08-2012 11:11 AM by adro. 17 replies.
Page 1 of 1 (18 items)
  • 01-03-2012 7:03 AM
    • Martin
    • Not Ranked
    • Joined on 11-28-2011
    • Graz / Austria
    • Posts 7
    • Gold Member
    Beo 6 and Samsung TV + Technisat Receiver
    Hello,
    this is my first post, so hello everybody and thanks for all the informations here!
    I am trying to configure my beo6 remote, but i am struggeling with the 3rd party products. I would like it to work with my samsung le 40a656 tv and technisat digit isio receiver in the living room. Also if possible with apple TV and really optional would be an old Sony A/V receiver. My B&O system in the living room is a beosound 3000 w/ beolab 6000 speakers.
    I assume that the Samsung TV file from a previous post here somewhere works fine with my TV but my real problem is the technisat receiver. I have found some sort of codes on the lintronic site for the digit isio (under supported products), but I am not sure how to proceed from here on...
    unfortunately I do not own any equipment to read codes from the remote directly.
    I was hoping someone could maybe explain me how to convert these codes on the lintronic site, or maybe there is even a easier way? Thank you,
    Martin.
    Beo6, Beosound 3000, Beolab 6000, Beo Century, Beosound 3.
    Samsung LE40A656, Technisat Digit Isio S1.
  • 01-03-2012 9:03 AM In reply to
    • BeoIce
    • Top 200 Contributor
    • Joined on 03-27-2007
    • Recklinghausen, Germany
    • Posts 281
    Re: Beo 6 and Samsung TV + Technisat Receiver
    Hi and welcome to Beoworld,
    I'm sorry, I can't give you any information on how to convert these codes, but Keith Saunders our Beo5/6 XML master can help you with that.
    I think he will be there soon Whistle
    Regards
    BeoSound 9000 MK III, BeoLab 6000, BeoLab 11, BeoCenter 2300, BeoSound Century, BeoVision MX4000/MX7000 & BeoCom 4
    Samsung UE40B7090, Samsung HT-WS1G, Technisat HD8-S, Sony PS3, Logitech PS3 IR-BT-Adapter & Lintronic TT455-RT-238
  • 01-03-2012 10:03 AM In reply to
    • Martin
    • Not Ranked
    • Graz / Austria
    • Posts 7
    • Gold Member
    Hi & thank you Smile
    No problem at all, I'm sure it will take some time to get the Beo6 perfect, so I'm not in a hurry ;) I've seen on the FAQ page and on the Beo5 page that Keith is probably the man for this ;) I just hope it's not too bothered by a beginner like me :D
    Regards,
    Martin.
  • 01-03-2012 2:46 PM In reply to
    Martin,
    A Very Warm Welcome to Beoworld..
    Controlling third party products that you have listed is not a problem, but you need to understand some of the limitations of the B&O Configuration Tool when it comes when trying to make changes to third party products. For this reason ALL 3rd party XML configuration files I produce will have hardkeys and digits and any other required elements pre-assigned, then it is just drag-n-drop within the Configuration Tool.
    Lets start with the easy requirement you have and that is the Apple TV, you can download an Apple TV XML file HERE which is contained within a ZIP file. Extract the ZIP file to C:\ and it will automatically place the XML file into the correct directory of the B&O Configuration Tool.
    In the Configuration Tool click on PRODUCTS then the tab marked OTHER and you will see Apple TV and you can just drag it into your configuration.
    Once you have tested it, let me know how you get on and then we can look at your next product.
    Regards Keith....
  • 01-03-2012 4:10 PM In reply to
    • Martin
    • Not Ranked
    • Graz / Austria
    • Posts 7
    • Gold Member
    Hi Keith,
    Thank you for the welcome and your help! Cool
    AppleTV and the Samsung TV are working now! Although the Samsung file doesn't seem to support all the functions... but it's more than good enough for the time being! I guess the Technisat won't be as simple, or is it?
    Thank you again, cheers Martin!
  • 01-03-2012 4:46 PM In reply to
    OK Martin..
    What is the model number of the Technisat ?
    We need to determine what protocol is used which I think is likely to be Philips RC6 protocol which is complex, but can be done.
    Regards Keith....
  • 01-03-2012 5:26 PM In reply to
    • Martin
    • Not Ranked
    • Graz / Austria
    • Posts 7
    • Gold Member
    it is the Technisat digit isio s1!
  • 01-04-2012 3:09 AM In reply to
    Martin,
    My research appears to show that this device uses Philips RC5 protocol (Carrier Frequency 36 Khz) and uses a device address of decimal 08
    Is the following remote the one with your unit ?
    Regards Keith....
  • 01-04-2012 3:16 AM In reply to
    Martin,
    With regards to your 4th requirement, the Sony AV Receiver, you may wish to try the XML file HERE
    You don't state the model, but this one may work
    Regards Keith....
  • 01-04-2012 5:20 AM In reply to
    • Martin
    • Not Ranked
    • Graz / Austria
    • Posts 7
    • Gold Member
    this is exactly the remote i use. i will try the sony xml meanwhile. i found these codes on the lintronic site which may be useful:
    705 008 000 000 014 000 000 0
    705 008 001 000 014 000 000 1
    705 008 003 000 014 000 000 3
    705 008 004 000 014 000 000 4
    705 008 005 000 014 000 000 5
    705 008 006 000 014 000 000 6
    705 008 007 000 014 000 000 7
    705 008 008 000 014 000 000 8
    705 008 009 000 014 000 000 9
    705 008 034 000 014 000 000 back
    705 008 110 000 014 000 000 blue
    705 008 033 000 014 000 000 channel down
    705 008 032 000 014 000 000 channel up
    705 008 121 000 014 000 000 display
    705 008 081 000 014 000 000 down
    705 008 052 000 014 000 000 fast forward
    705 008 108 000 014 000 000 green
    705 008 079 000 014 000 000 info_vor
    705 008 085 000 014 000 000 left
    705 008 082 000 014 000 000 menu
    705 008 013 000 014 000 000 mute
    705 008 105 000 014 000 000 nav
    705 008 116 000 014 000 000 next
    705 008 087 000 014 000 000 ok
    705 008 010 000 014 000 000 opt
    705 008 088 000 014 000 000 pip
    705 008 053 000 014 000 000 play
    705 008 012 000 014 000 000 power
    705 008 055 000 014 000 000 record
    705 008 107 000 014 000 000 red
    705 008 050 000 014 000 000 rewind
    705 008 086 000 014 000 000 right
    705 008 047 000 014 000 000 sfi
    705 008 038 000 014 000 000 sleep
    705 008 041 000 014 000 000 still
    705 008 054 000 014 000 000 stop
    705 008 060 000 014 000 000 text
    705 008 106 000 014 000 000 timer
    705 008 035 000 014 000 000 ton_sound
    705 008 083 000 014 000 000 tv_radio
    705 008 080 000 014 000 000 up
    705 008 017 000 014 000 000 volume down
    705 008 016 000 014 000 000 volume up
    705 008 127 000 014 000 000 www
    705 008 109 000 014 000 000 yellow
    705 008 126 000 014 000 000
    zoom
  • 01-04-2012 6:54 AM In reply to
    Martin,
    Thank you for confirming which remote you have for the Technisat.
    I can confirm that I have made an XML file based on your remote which can be downloaded from HERE and extracted from the ZIP file as previously stated.
    Regards Keith....
  • 01-04-2012 9:13 AM In reply to
    • Martin
    • Not Ranked
    • Graz / Austria
    • Posts 7
    • Gold Member
    Keith,
    It is now everything up and running! Thank you so much for your time and effort!! You are doing an amazing job around here :)
    Thanks again,
    Cheers Martin.
  • 01-04-2012 3:39 PM In reply to
    • Martin
    • Not Ranked
    • Graz / Austria
    • Posts 7
    • Gold Member
    Especially the hard key assignment is really well done Cool
  • 01-05-2012 3:31 AM In reply to
    • adro
    • Not Ranked
    • Joined on 08-26-2009
    • Posts 23
    • Gold Member
    Hallo.
    Keith, could you please explain the difference between having the hardkeys and digits etc. pre-assigned in the XML file, vs just program the keys in the Configuration Tool.
    Rgds
    AtleSmile
  • 01-05-2012 2:55 PM In reply to
    Atle,
    There are two main reasons for pre-assigning hardkeys, digits and logos within the 3rd party XML file before using it in the B&O Configuration Tool
    1. The user can just drag-n-drop the 3rd party product in their existing configuration and need make no further modifications. So its just a matter of adding it to your existing configuration and downloading the configuration to the Beo5/6. Very quick and will take less that one minute to add and download.
    2. Many changes you may wish to make to the 3rd party product within the Configuration Tool either don't work or work incorrectly.
    All Beo5/6 configurations and product information is stored in a large number of XML files. When you add any product 3rd party or B&O to your main configuration you are effectively adding one XML file to another using the initial structure setup when you first created your zones.
    So, you are now going to ask "What is an XML file?"
    In simple terms XML stands for eXtensible Markup Language and is designed to transport and store data. XML defines a set of rules for encoding documents in a format that is both human-readable and machine-readable and is in a flat text file which can be opened with any text editor.
    Regards Keith....
  • 01-06-2012 5:34 PM In reply to
    • adro
    • Not Ranked
    • Posts 23
    • Gold Member
    Thanks Keith.
    Ok, I can see the advantage of getting a file with pre-assigned hardkeys etc, but  how do you program this in to the files?
    Do you just manually type everything in, or is it cut and past, or?
    Regards
    Atle.
  • 01-07-2012 5:20 PM In reply to
    Atle,
    I do NOT cut-n-paste within the XML file as this would take a very long time.
    Some 2 years ago I spent several months developing a Windows based program which took much of the hard work out of creating full 3rd party XML with everything needed for that product pre-assigned. Below is a screen shot to allow you to understand how I do it. Also, if you open one of my XML files with a text editor you will be able to see the XML structure used.
    Regards Keith....
  • 01-08-2012 11:11 AM In reply to
    • adro
    • Not Ranked
    • Posts 23
    • Gold Member
    Keith,
    Well I guessed it was something like that. I have looked at a few of your files, trying to figure out the structure/system .I have also made a few XML's of my own, but I had to do cut-n-paste. Then as you say, it takes a long time, and it is very easy to do mistakes, by leaving out a character or two.
    I guess you do not want to share your software Big Smile
    Atle
