        1st March February 2012
	    Latest post 01-03-2012 8:00 PM by dmacri . 20 replies.
								    |  01-02-2012 6:05 PM |  |
									                 reffubJoined on 01-02-2012Posts 1 |
										    What is the best system that B&O made if we are talking about there "staked" system?   Happy new year all  |  |
									                 Hungedu
 Joined on 08-08-2009Ambergris Caye, BelizePosts 128 |
										    BeoSound 9000, but if you mean only "stacked" systems, that would be the 7000 system.
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.   |  |
									                 Søren Hammer
 Joined on 01-07-2008Esbjerg/DenmarkPosts 554 |
										    There are a few opinions on that. The Beosystem 5000 is the first stacked system. Generally: A CD-player with a very solid laser that is unlikely to fail (the CD50, also included in early Beosystem 5500 sets). Beogram CD5500/6500 and 7000 are also reliable performers. An, In my opinion superior cassette deck. Much of the electronics comes from the Beocord 8004 and the mechanics from the Beocord 2000/3000. It is not equipped with the nice autoreverse and auto-dolby system but I would definately choose the Beocord 5000 among the others if I was allowed to have only one cassette deck. The Beocord 5500/6500/7000 are very similar, with equally similar specs and functions. They are versatile and user-friendly, and they actually sound way better than expected. It is a bit difficult to adjust the levels correctly as the level meter only displays one channel, and is not reacting the way I would like it to though I have made many good recording on my Beocord 5500. The Beomaster is a little different compared to it's later counterparts. A simpler remote system was equipped which was in many ways similar to the Beomaster 8000 remote system. The newer stacking Beomasters had the newer Beolink 1000-type codes and later PowerLink which increased versatility. The Beogram record player was firstly the Beogram 5000, a radial tracking player deriving from the Beogram 1800-series. Later systems came with the Beogram 5005 and 5500 which are a newly developed generation of tangential trackers. Beogram 6500 and 7000 is exactly the same, the only difference was that the RIAA preamplifier was equipped in the record player instead of the earier standard of the RIAA equipped in the Beomaster. There are also small differencies in how they look. The 5000 system is gray with satin matt aluminium strip. Standby LED's lights at equal luminance. The 5500 is available in white, and a special painted grey/black finish was made as a prototype (very very rare, but I know a Danish B&O collector who owns one). The 6500 was made in glossy black and so was the 7000. Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993. |  |
									                 j0hnbarkerJoined on 04-16-2007LS28/GBPosts 2,002 |
										    Setting aside cool remotes and greater connectivity options, I would say anything WITH a CD50. It's a great CD player and the 5000 amp is better than the later series if using passive speakers. Also, get the tangential record decks - the radial one is poo, despite what you might hear to the contrary :P President, Beomaster 8000 Appreciation Society |  |
									                 bayerischeJoined on 12-11-2007Helsinki, FinlandPosts 3,593 |
									    -Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2     |  |
									                 kallasr
 Joined on 04-19-2007Willich, NRW, GermanyPosts 1,077 |
										    Black Beosystem 7000. <---- (as you can see taking a look at my avatar  ) Ralf My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1. |  |
									                 Leslie
 Joined on 05-07-2009NetherlandsPosts 2,201 |
										     kallasr:
 Or in my closet B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Rich
 Joined on 07-10-2010Orlando, Florida, USAPosts 1,089 |
										    A stack system will be the next thing I collect.  I am very interested in reading stack owners' opinions.   Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70    |  |
									                 DoctorJoined on 09-14-2010Posts 555 |
										    There is no best system. Of the components: The best amplifier is the 5000 - unless you have active speakers in which case it is the 7000. The best CD player is the CD5500 (the CD50 is far too unreliable , and is simply too weird - a single channel DAC!?? - the fact that hardly two are the same design)  The best cassette player is the 5000 - unless you really want auto-reverse.  The best remote is the 7000 - as long as you have a Beomaster 6500 or 7000. The best record player is the 5000 - best made and best sounding. The tangential ones are more convenient.    Of course the best stacking system really is the Beolab 5000 system of 1967! |  |
									                 Bentleyman
 Joined on 12-29-2008RochdalePosts 367 |
										    Yes, And I think one of the best ways to position and display your component stack system is in the 2 + 2 configuration like so....
   Instead of the turntable unit (I dont have any records), I have a 2nd CD unit plugged into the PHONO socket, so the system pictured above is a mish-mash of 6500/7000 units (2 of each). I agree the BL7000 is the best remote, but I do like the wedge design and display read~out on the MCP6500 too   Regards, Michael BV5, BV Avant, MX4000, MX1500 BS 7000, BS 5500  Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu  BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2) |  |
									                 Leslie
										    Or 2+2+2+2
									                 Bentleyman
 Hahaha nice one!
									                 Leslie
										    @Michael, there must be a way to promote my stuff B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Steffen
 Joined on 06-24-2008DenmarkPosts 281 |
										     Søren Hammer:Much of the electronics comes from the Beocord 8004 and the mechanics from the Beocord 2000/3000.
   Was there ever a Beocord 3000???I think you mean the 3300  Btw. the later models of the Beocord 7000 had a different tape mechanism -i think it was a cheaper one (maybe from the Ouverture).My experience is that the BC7000 i once had, didn't sound as good as my BC6500. Maybe it was worn - or out of adjustment.
 I sold my (black) Beosystem 7000 a few years ago -which i regret now [:'(] I would surely like to have another system to put up next to my alu/black 6500 system. (I like your 2+2+2+2, Leslie)
									                 Leslie
										     Tod Daniel:
I really makes me sad that this beautiful range is so much nicer than the B&O hifis of today - their range now is a bit of a mess and not very desireable!  These vintage systems are simply superb!
 Sure thing Tod! However, I prefer the complete Beosystem 4500, got 5 of those systems but not enough walls B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Steffen
										     Leslie:
 Tod Daniel:
 I agree!!! I have a System 6500, a System 4500 and a BeoCenter 9500 which i use regularly. Besides I have a System 5000.I can't decide which is the best looking...love them all.
 I haven't bought a B&O audio unit since the BeoSound 2300. As you say - the range today is a bit of a mess. As if they don't know which way to go with their design... Those who try to please everyone, might end up making no one happy...
 But...It seems they can capture the attention of the I-pod/pad/phone generation with the BS 8. Good luck with that.Just a bit sad, that so many people today prefer to listen to MP3 files through earplugs and I-pod docks -instead of listening to a good audio system and some decent speakers.
									                 dmacri
 Joined on 05-03-2008Posts 63 |
										    I'm thrilled with my BS5000 since I have all passive speaker systems. I find the sound quality of the BM5000 to be very similar to my BeoCenter 3500. My preference is the 5000 due to the flexibility of datalink and the expadibility  of the MCL82 links.BeoSystem 5000 (BM 5000, BG 5005, BC 5000, CD50), BeoCenter 3500, BeoCenter 2500, BeoLab 2500, BeoVox S-45, S-45.2, RL-140, CX-100, CX-50, C-75, 3 MCL82 link rooms, A8, 4001 relay and ambio  |  |
						     Page 1 of 1 (21 items)  |
