Ok try this for me:
- Plug NAS directly into BeoSound 5e via ethernet.
On the NAS:
- Set a static IPv4 for the network card - e.g. 192.168.2.1
Subnet Mask: 255.255.255.0
Default Gateway: <Blank>
Then set primary DNS as 192.168.2.1 (or whatever IP you chose above), and leave secondary DNS blank.
On the BS5e:
- Go to network settings
- Disable DHCP
- Set network manually
- Set the IP to an increment of the ip above. so e.g. 192.168.2.2
- Set default gateway to the IP of the NAS - e.g. 192.168.2.1
- Set primary DNS to the IP of the NAS 192.168.2.1
- Reboot BS5e (now might be a good time to reboot your NAS too to rule out any possible problems)
- Move slider to MODE. The highlight settings, press > > (twice) and then press GO to enter into settings.
- Move the slider to Service Settings, Music Storage, and see if it picks up your NAS.
- Also check Network info in settings to see if it is connecting successfully. And on the NAS make sure to allow any connections should it ask/allow it through firewall.
