1st March February 2012
Latest post 01-12-2012 3:33 AM by Dave0280. 16 replies.
12-23-2011 9:03 AM
Dave0280
- Joined on 03-05-2008
- Birmingham, UK
- Posts 126
Beosound 9000 clamper height adjustment
Hi all,
After a new laser the BS9000 was working great but now i get a slight scraping on CDs 2 and 4. Don't want to leave it until it gets much worse so has anyone adjusted their clamper height and for a B&O DIY novice is it worth tackling or getting it sorted professionally? The system has been mounted vertically and never moved so all settings are correct.
Thanks all and Merry Christmas and a Very Happy and Healthy 2012 to all
Dave
Dave - Birmingham, UK
Dave0280
- Birmingham, UK
- Posts 126
Re: Beosound 9000 clamper height adjustment
Hi Jason, yes all are ok and were checkedwhen i had my new laser fitted. The scraping has gradually come on over the past 6 months. Frustrating but not marking the CDs as yet so only just touching the tops of CDs 2 and 4.
Dave0280
- Birmingham, UK
- Posts 126
Hi Jason, yes all are ok and were checked when i had my new laser fitted. The scraping has gradually come on over the past 6 months. Frustrating but not marking the CDs as yet so only just touching the tops of CDs 2 and 4.
Iconic-AV
- Joined on 04-16-2007
- Birmingham UK
- Posts 902
Hi Dave,
where did you get the laser changed?
Dave0280
- Birmingham, UK
- Posts 126
Hi Jason, it was done by Kevin at East TV about 12 months ago, he quoted £70+VAT to come out to adjust the clamper which is a bit hefty at this time of year - do you know of anyone in Brum?
valve1
- Joined on 05-27-2009
- Dublin Ireland
- Posts 213
Dave0280: do you know of anyone in Brum?
I know a helpfull guy who might live near you, Jason in Iconic-av......... :-) !
Iconic-AV
- Birmingham UK
- Posts 902
valve1:
Out of respect for the offical engineers around the uk, we dont advertise to or offer a repair service unless the item was purchased from us.
But thankyou for your kind words
Dave0280
- Birmingham, UK
- Posts 126
I will have a play with the settings at the back today - I didn't know if you had your own repair guys locally but will keep you in mind in the future . Will report back when i've had a fiddle....
Dave0280
- Birmingham, UK
- Posts 126
I've checked and put the adjustment arrows back to its vertical position but no change. Didn't want to try them in any other position as didn't want to cause any problems - can i try them in other positions even though its vertically mounted?
Hungedu
- Joined on 08-08-2009
- Ambergris Caye, Belize
- Posts 128
I have experienced the CD scraping sound as well. I tried an experiement and replaced all of the CDs in the player, and the scraping stopped. My guess is that if you leave the same CDs in the BS 9000 system for an extended period, the discs become slightly bowed or warped, and as a result, scrape against the clamping mechanism during movement.
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
Dave0280
- Birmingham, UK
- Posts 126
I've replaced all my CDs as i thought that 2 had bowed or something similar but its any CDs in the 2 and 4 positions.
Hungedu
- Posts 128
Hmm. That's strange. Maybe some kind of adjustment is needed, but I'm not sure why it would only affect numbers 2 and 4. Maybe the spring-loaded CD holders on 2 and 4 are sticking out too far, but I guess a simple adjustment to the clamper will correct it. If you get this done, please let us know how it works out. I might consider this solution as well.
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
The arrow adjusters under the machine will not help here. They simply bias the CD mech suspension to allow for the various orientation possibilities with different mounting options. I suggest that you return them to the recommended settings.
The clamper cover has sagged slightly so that it is no longer paralel to the bed of the machine. It needs lifting a fraction at the front.
There is an adjustment described in section 5-5 of the service manual and described as "adjustment of clamper arm".
There are two allen screws provided to facilitate the adjustment. Note that anti-clockwise adjustment will lift the front of the clamper arm. (0.5 of a turn will probably be sufficient)
Dave0280
- Birmingham, UK
- Posts 126
Cheers Graham - will give it a go.
Dave0280
- Birmingham, UK
- Posts 126
Problem solved with some advice and guidance from Jason at Iconic-AV. I now have my BS9000 working as it should so a massive thanks to Jay and no doubt i'll be spending some money there in the near future - still got to convince the wife that Pentas look nice so i can have a pair again! My worst B&O decision ever - selling my MK2's a few years ago......
Thanks Jay - your a star mate. See you soon
Page 1 of 1 (17 items)
