Latest post 01-12-2012 3:33 AM by Dave0280. 16 replies.
Page 1 of 1 (17 items)
  • 12-23-2011 9:03 AM
    • Dave0280
    • Top 500 Contributor
    • Joined on 03-05-2008
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Beosound 9000 clamper height adjustment
    Hi all,
    After a new laser the BS9000 was working great but now i get a slight scraping on CDs 2 and 4. Don't want to leave it until it gets much worse so has anyone adjusted their clamper height and for a B&O DIY novice is it worth tackling or getting it sorted professionally? The system has been mounted vertically and never moved so all settings are correct.
    Thanks all and Merry Christmas and a Very Happy and Healthy 2012 to all
    Dave
    Dave - Birmingham, UK
    Filed under: ,
  • 12-23-2011 9:54 AM In reply to
    Re: Beosound 9000 clamper height adjustment
    Have you checked the 2 adjustments at the back are set to the right position?
    jason
  • 12-23-2011 10:50 AM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Hi Jason, yes all are ok and were checkedwhen i had my new laser fitted. The scraping has gradually come on over the past 6 months. Frustrating but not marking the CDs as yet so only just touching the tops of CDs 2 and 4.
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Hi Jason, yes all are ok and were checked when i had my new laser fitted. The scraping has gradually come on over the past 6 months. Frustrating but not marking the CDs as yet so only just touching the tops of CDs 2 and 4.
  • 12-23-2011 12:06 PM In reply to
    Hi Dave,
    where did you get the laser changed?
    jason
  • 12-28-2011 12:14 PM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Hi Jason, it was done by Kevin at East TV about 12 months ago, he quoted £70+VAT to come out to adjust the clamper which is a bit hefty at this time of year - do you know of anyone in Brum?
  • 12-28-2011 1:20 PM In reply to
    have you tryed slightly adjusting the 2 settings at the back until it stops rubbing and plays well?
    jason
  • 12-28-2011 1:28 PM In reply to
    • valve1
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Dave0280:
       I know a helpfull guy who might live near you, Jason in Iconic-av......... :-)   !
  • 12-28-2011 2:23 PM In reply to
    valve1:
    Dave0280:
    Out of respect for the offical engineers around the uk, we dont advertise to or offer a repair service unless the item was purchased from us.
    But thankyou for your kind words Yes -  thumbs up
    jason
  • 12-29-2011 5:31 AM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    I will have a play with the settings at the back today - I didn't know if you had your own repair guys locally but will keep you in mind in the future Big Smile. Will report back when i've had a fiddle....
  • 01-03-2012 12:38 PM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    I've checked and put the adjustment arrows back to its vertical position but no change. Didn't want to try them in any other position as didn't want to cause any problems - can i try them in other positions even though its vertically mounted?
  • 01-03-2012 2:12 PM In reply to
    • Hungedu
    • Joined on 08-08-2009
    • Ambergris Caye, Belize
    • Posts 128
    I have experienced the CD scraping sound as well. I tried an experiement and replaced all of the CDs in the player, and the scraping stopped. My guess is that if you leave the same CDs in the BS 9000 system for an extended period, the discs become slightly bowed or warped, and as a result, scrape against the clamping mechanism during movement.
    BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
  • 01-03-2012 3:59 PM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    I've replaced all my CDs as i thought that 2 had bowed or something similar but its any CDs in the 2 and 4 positions.
  • 01-03-2012 6:48 PM In reply to
    • Hungedu
    • Posts 128
    Hmm. That's strange. Maybe some kind of adjustment is needed, but I'm not sure why it would only affect numbers 2 and 4. Maybe the spring-loaded CD holders on 2 and 4 are sticking out too far, but I guess a simple adjustment to the clamper will correct it. If you get this done, please let us know how it works out. I might consider this solution as well.
  • 01-06-2012 8:29 AM In reply to
    The arrow adjusters under the machine will not help here. They simply bias the CD mech suspension to allow for the various orientation possibilities with different mounting options. I suggest that you return them to the recommended settings.
    The clamper cover has sagged slightly so that it is no longer paralel to the bed of the machine. It needs lifting a fraction at the front.
    There is an adjustment described in section 5-5 of the service manual and described as "adjustment of clamper arm".
    There are two allen screws provided to facilitate the adjustment. Note that anti-clockwise adjustment will lift the front of the clamper arm. (0.5 of a turn will probably be sufficient)
    Regards Graham
  • 01-09-2012 1:56 PM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Cheers Graham - will give it a go.
  • 01-12-2012 3:33 AM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Problem solved with some advice and guidance from Jason at Iconic-AV. I now have my BS9000 working as it should so a massive thanks to Jay and no doubt i'll be spending some money there in the near future - still got to convince the wife that Pentas look nice so i can have a pair again! My worst B&O decision ever - selling my MK2's a few years ago......
    Thanks Jay - your a star mate. See you soon
