The first question is, are the bedroom and living room systems connected together by Masterlink? If no, you will need to connect them. If yes, have you renamed your N.Music and N.Radio functions on BeoSound 5 to Radio and CD? If yes, you will not be able to control it from the BeoCenter 2. If no, you can access your BeoSound 5 from your BeoCenter 2 with the Beo 4 by selecting N.Music or N.Radio from your List button. You can also go into the menu(List) of your BeoCenter 2 and add N.Music and N.Radio as a function. Once you have done that, you can exit and hit List on the BeoCenter 2 and you should see N.Music and N.Radio. Hope this helps.
Joe
Its not just a product, its a way of life...
