Latest post 12-12-2011 8:23 AM by joeyboygolf. 18 replies.
Page 1 of 1 (19 items)
  • 12-10-2011 8:39 AM
    Display for Penta II
    I require a complete working display module for a Beolab Penta II
    Any one help out?
    Perhaps you are scrapping a pair of Penta II and have the displays available?
    Will pay!!!!
    Regards Graham
  • 12-10-2011 2:03 PM In reply to
    Re: Display for Penta II
    You missed this one and guess who bought itWhistle
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 12-10-2011 2:40 PM In reply to
    Leslie, I am disabled and retired from work. I am watching eBay.co.uk more than 18 hours a day so I miss very little of interest. That display or one very similar has been on before.
    I saw that display this time but I didn't need one at the time.  I do now!
    PM me if you want to sell it.
    Regards Graham
  • 12-10-2011 4:33 PM In reply to
    At the moment I'm refurbishing my Penta II's (what else do I doSmile) and will finish this project tomorrow. One display has failed, that's why I bought it. But there's hope since I remember after the purchase I already had one in my "closet" Ick!. Have to test it first and if ok we can do businessWink Will let you know by tomorrow!
  • 12-10-2011 4:53 PM In reply to
    Replace the large electrolytics on the display board before deciding that you need another one.
    -mika
  • 12-10-2011 5:19 PM In reply to
    Leslie:
    Thanks Leslie
    Regards Graham
  • 12-10-2011 5:32 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I am curious, do the micros fail in these often or do the faults tend to be less serious?
    tournedos:
    Olly.
  • 12-10-2011 5:49 PM In reply to
    Tired caps is the only systematic fault I have heard of.
    Otherwise the boards have very little to fail. Mk.I runs on i8049 and the II/III apparently both on 80C52. None of these are particularly sensitive to ESD but careless handling can undoubtedly kill all of them.
    -mika
  • 12-10-2011 11:59 PM In reply to
    This one has been repaired several times. It has now failed again and it is at the stage where it is more down than up!
    It is time to replace it!
    Regards Graham
  • 12-11-2011 2:35 AM In reply to
    Could it be possible that the display has a defect? To do fault finding I would have swapped the display to make sure where the fault is, either the PCB or display.
  • 12-11-2011 7:36 AM In reply to
    Yes the display has a defect. Yes the pcb's have a defect. They have been repaired on numerous occasions.
    Now is the time to replace them.
    Regards Graham
  • 12-11-2011 8:33 AM In reply to
    joeyboygolf:
    Lifting Beolab Penta's and Beovox 5000 (the old type) gave me serious back problems now! Can't test the display board GrahamEmbarrassed
    Tomorrow my dear wife will send you the display/board as I'm not able to do anything nowSuper Angry. Try it first and let me know!
  • 12-11-2011 8:48 AM In reply to
    Leslie:
    joeyboygolf:
    Many thanks Leslie. You have my address?
    Regards Graham
  • 12-11-2011 9:01 AM In reply to
    Yes I have, I presume it's still the same adress in Ely?
  • 12-11-2011 9:07 AM In reply to
    Yes, it is.
    Regards Graham
  • 12-12-2011 7:13 AM In reply to
    You  got PM!
  • 12-12-2011 7:36 AM In reply to
    Not yet!!
    Regards Graham
  • 12-12-2011 7:57 AM In reply to
    Not Beoworld mail but your private mail?
  • 12-12-2011 8:23 AM In reply to
    No, nothing.
    I have sent you an email from beo4life so you can reply.
    Regards Graham
