1st March February 2012
Latest post 12-12-2011 8:23 AM by joeyboygolf. 18 replies.
12-10-2011 8:39 AM
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
I require a complete working display module for a Beolab Penta II
Any one help out?
Perhaps you are scrapping a pair of Penta II and have the displays available?
Will pay!!!!
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
You missed this one and guess who bought it
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
joeyboygolf
- Posts 3,252
Leslie, I am disabled and retired from work. I am watching eBay.co.uk more than 18 hours a day so I miss very little of interest. That display or one very similar has been on before.
I saw that display this time but I didn't need one at the time. I do now!
PM me if you want to sell it.
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
I am curious, do the micros fail in these often or do the faults tend to be less serious?
tournedos:
Replace the large electrolytics on the display board before deciding that you need another one.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Tired caps is the only systematic fault I have heard of.
Otherwise the boards have very little to fail. Mk.I runs on i8049 and the II/III apparently both on 80C52. None of these are particularly sensitive to ESD but careless handling can undoubtedly kill all of them.
Leslie
- Netherlands
- Posts 2,201
Could it be possible that the display has a defect? To do fault finding I would have swapped the display to make sure where the fault is, either the PCB or display.
Leslie
- Netherlands
- Posts 2,201
joeyboygolf:
Yes the display has a defect. Yes the pcb's have a defect. They have been repaired on numerous occasions.
Now is the time to replace them.
Lifting Beolab Penta's and Beovox 5000 (the old type) gave me serious back problems now! Can't test the display board Graham
Tomorrow my dear wife will send you the display/board as I'm not able to do anything now . Try it first and let me know!
joeyboygolf
- Posts 3,252
Leslie:
joeyboygolf:
Many thanks Leslie. You have my address?
Leslie
- Netherlands
- Posts 2,201
Yes I have, I presume it's still the same adress in Ely?
Leslie
- Netherlands
- Posts 2,201
Not Beoworld mail but your private mail?
Page 1 of 1 (19 items)
