Recently my cherished BeoMaster 3000 has been popping and
cracking.
If I’m using Phono or Tape input and its been on for about 10
minutes (enough time to heat up) it will start popping and eventually gets
unlistenable. If i put the unit into standby for a while and then back on it
will still be popping but after a while unlistenable again.
Interestingly it does not start popping if I’m using FM and when
it does pop on the other inputs the STEREO light comes on and the 2 light above
STANDBY are on (The ones witch normally indicate FM signal strength)
I have talked to a few people and they seem to think it might be
the power supply; maybe the radio uses a different part of the supply. I have
opened it up and couldn’t see any sign on a burnt out capacitor.
Any ideas on what’s wrong with it? And more importantly how do I
fix it!
