Latest post 12-09-2011 3:12 AM by Vienna. 4 replies.
Page 1 of 1 (5 items)
  • 12-04-2011 5:43 AM
    • zazouzt
    • Top 500 Contributor
    • Joined on 04-17-2007
    • near Strasbourg/France
    • Posts 123
    BEOLINK PC2
    Hi all,
    I installed a beolink PC2 between my computer and my BV3 32, wich are in different rooms.
    The software installation of Beoport was OK.
    Bur now, when i will go to Config, it doesn't work; it begins, the little window appears quickly but doesn't stay.
    What can be wrong ?
    Thanks for you help.
    ZazouEmbarrassed
  • 12-04-2011 12:37 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: BEOLINK PC2
    zazouzt:
    Most common mistakes during installation of a Beoport/PC2 are:
    - erroneously installing BeoPlayer software - you need the BeoPort version
    - connecting all wires and start the installation after
    - it's mandatory to follow this procedure:
    - connect all cables EXEPT the USB between PC and BEOPORT/PC2
    - start installing the BeoPort software
    - you'll be informed when you have to connect the USB cable
  • 12-06-2011 9:30 AM In reply to
    • zazouzt
    • Posts 123
    Re: BEOLINK PC2
    That's what i have done.
    All wires were connected  except USB cable.
    The installation started and asked me to connect the Usb cable, and then finished normally.
     I restarted the computer, but then i had the trouble i described.
    I think, i'll try another installation ;i have the Beoport software, but i'll have a look if beoplayer software is still here, and delete it if yes.
    Zazou
  • 12-08-2011 2:02 PM In reply to
    • zazouzt
    • Posts 123
    Re: BEOLINK PC2
    i uninstalled all Beoplayer and Beoport etc.. i found and started again the installation with the Cd Beolink PC2, and it changed nothing.
    when i try to do  Config ,  the windows doesn't stay, so i can't do anything.
    i wanted to select all files to play as it does only play one file
    Zazou
  • 12-09-2011 3:12 AM In reply to
    • Vienna
    • Posts 712
    Re: BEOLINK PC2
    In many cases SW versions on CDs are outdated.
    The most recent version of BeoPlayer is 5.04. (download via B&O homepage)
    If your are using Win 7, your dealer can download the BeoPort "service software 6.02"
    for you. This version is solving some Win 7 issues and is fully compatible to Vista and XP.
    During istallation you have to be logged in as admin (or with admin rights)
