That's what i have done.
All wires were connected except USB cable.
The installation started and asked me to connect the Usb cable, and then finished normally.
I restarted the computer, but then i had the trouble i described.
I think, i'll try another installation ;i have the Beoport software, but i'll have a look if beoplayer software is still here, and delete it if yes.
Zazou
