Dear all.
I have read several threads on this forum on this very topic, and I have been unsuccesful in solving this problem. Therefore, I would appreciate any advice I can get.
I have purchased a new AppleTV, and I do get picture, via the DVI port on AV4. The problem is that there is no sound. I tried to overcome this by buying a digital audio converter, specifically an HQ-CONV-OPCOAX, which has an optic input and a co-axial output. I then connected the co-axial cable to A1, to A2, to A3 and A4 - without any success.
I have spoken to two local B&O dealers, who have not been able to help me resolve the issue.
Having written to B&O in Denmark, I got the following answer:
"For analogue sound connection on new Apple TV version you need to connect “Optical to Analogue converter”, Toslink and Phono cables.
Also here it is necessary that you have the correct DSM and AP softwares, which your dealer can help with, and PCM must be set to ON in the Customer Service Menu.
For digital sound you need to connect “Optical to Coaxial S/P-Dif”, Toslink and Phono cable, and again he correct DSM and AP softwares, and PCM set to ON in the Customer Service Menu. Please also note that only analogue sound can be distributed to link rooms."
I have three questions, therefore.
1. Since I already have the Optical to Co-axial converter, I wonder if some of you have been succesful in using this? What am I doing wrong, or not doing?
2. Have any of you purchased an optical to analogue converter, and been succesful in connecting the AppleTV? The 'audio socket' option on AV4, which is the only place I can connet the DVI cable, only allows "A1, A2, A3 or A4", and so I wonder whether this is an option at all?
3. Is this at all possible, or should I give up?
I do hope you can help, it would be the best X-mas present ever!
