I noticed that my MLGW showed software version 1.80. . .
Does anyone know what the specifics of the new software are?
MJM
I'm ready for something new that I actually want to buy!
Support for some third party systems and better compatibility with the Atlona Matrix.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
At present the following 3rd party products are directly (meaning built in) supported:-
It should be noted that if a Masterlink gateway is installed into an existing Masterlink enviroment with products older than about 18 months, then they almost certainly will need a software update. In the case of products such as Beolink Passive and Active, they will require a chip change.
Regards Keith....
