Latest post 12-02-2011 9:57 AM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 12-01-2011 9:10 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    MLGW Software Update
    I noticed that my MLGW showed software version 1.80. . .
    Does anyone know what the specifics of the new software are?
    MJM
    I'm ready for something new that I actually want to buy!
  • 12-02-2011 12:00 AM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • New York, NY
    • Posts 176
    Re: MLGW Software Update
    Support for some third party systems and better compatibility with the Atlona Matrix.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 12-02-2011 9:46 AM In reply to
    What third party systems are supported by it?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 12-02-2011 9:57 AM In reply to
    At present the following 3rd party products are directly (meaning built in) supported:-
    • Crestron
    • AMX
    • Control 4
    • LK/IHC, Schneider/LexControl and ELKO
    • Lutron Grafik Eye (GRX)
    • Lutron Grafix QS (QSE)
    • Lutron Radio RA
    • Lutron Radio RA2
    • Lutron Home Works Interactive
    • Conson Concept XP (converter from RS 485 to RS 232 is needed)
    • KNX compatible systems
    • Either TCP/IP or RS232
    • Clipsal
    • Dynalite
    • Vantage
    • BTicino My Home
    • Systems with simple RS232 or IP command and status strings
    It should be noted that if a Masterlink gateway is installed into an existing Masterlink enviroment with products older than about 18 months, then they almost certainly will need a software update. In the case of products such as Beolink Passive and Active, they will require a chip change.
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
