Latest post 12-20-2011 7:28 AM by Raeuber. 7 replies.
Page 1 of 1 (8 items)
  • 12-01-2011 12:30 PM
    PUC for Technisat Digicorder
    Hi all,
    can anybody provide me with a list that shows the Beo4-keys of the Technisat remote (http://www.technisat.com/de_DE/TechniControl/352-101-1298898209402/)?
    My Beovision has the PUC list of the Techisat DigiCorder ISIO already installed, but I have some trouble to find all the commands of the Technisat remote on my Beo 4.
    Thanks!
    /Räuber
  • 12-01-2011 1:03 PM In reply to
    Re: PUC for Technisat Digicorder
    I am guessing that the following is what you are looking for:-
    Regards Keith....
  • 12-01-2011 1:35 PM In reply to
    Thanks Keith!
    But I think the list is for older Technisat receivers, there must exist another list for the new Technisat ISIO (with p.e. WWW and NAV key).
    /Räuber
  • 12-01-2011 2:07 PM In reply to
    Räuber,
    I guess I was just looking at the word Digicorder, but I think the following is what you are looking for:-
    Regards Keith....
  • 12-01-2011 2:17 PM In reply to
    Yes, this is exactly what I need.
    Thank you very much!!
    Regards
    Räuber
  • 12-13-2011 1:28 PM In reply to
    Hi Keith,
    do you have the PUC list also for the Beo 4 with Nav-button (1710)?
    /Räuber
  • 12-20-2011 4:25 AM In reply to
    Räuber,
    Below is the mapping for the Beo4 Type # 1710
    Regards Keith....
  • 12-20-2011 7:28 AM In reply to
    Thanks Keith!
    I probably want to buy a Beo4 1710, not because of the Technisat but because of the Bluray-Player. With Beo4 1625 you always have to press the yellow button to send an action!
    But I often want to hear radio with my Technisat over a Beolink passive without switching the BV 7-40 on. On Beo 4 1625 I have to press LINK DTV and then GO 6 to switch from TV to Radio. MENU 6 doesn't work in this situation, this only works if BV 7-40 is switched on!
    So what to do with a Beo4 1710? I assume MENU 6 doesn't work and there is no GO button on Beo4 1710 anymore.
    Do you know a solution?
    /Räuber
