Thanks Keith!
I probably want to buy a Beo4 1710, not because of the Technisat but because of the Bluray-Player. With Beo4 1625 you always have to press the yellow button to send an action!
But I often want to hear radio with my Technisat over a Beolink passive without switching the BV 7-40 on. On Beo 4 1625 I have to press LINK DTV and then GO 6 to switch from TV to Radio. MENU 6 doesn't work in this situation, this only works if BV 7-40 is switched on!
So what to do with a Beo4 1710? I assume MENU 6 doesn't work and there is no GO button on Beo4 1710 anymore.
Do you know a solution?
/Räuber
