Latest post 11-30-2011 12:39 PM by Mark. 12 replies.
Page 1 of 1 (13 items)
  • 11-29-2011 12:32 PM
    • Mark
    • Not Ranked
    • Joined on 03-23-2010
    • Iver Village, Nr Heathrow
    • Posts 11
    Can't play Cars2 BluRay on BeoVision 7-55 (now with fix)
    Just wondering if anyone else has had an issue trying to play Cars 2 on BluRay using a BeoVision 7-55?
    Bought one copy from Amazon and it would not play. Bought another one from Tesco tonight and again it won't play.
    I get to the menu where I choose English then all I get is just the Disney Castle screen and the moving water/refelction.
    The counter goes up in mins but even after 5 mins nothing happens.
    Both discs play on my Sony BluRay player so it can only be the BeoVision.
    Anyone have any ideas? Firmware issue maybe? Doddy BluRay player? (Always have thought it was slow and pausing/playing is a total pain).
    Mark Smile
    Beovision 7 55 with BluRay, Beolab 9's, Beosound 8, Penta 3's, Overture, Beocom 2, Beo 6 Remote
  • 11-29-2011 3:46 PM In reply to
    Re: Can't play Cars2 BluRay on BeoVision 7-55
    Hi
    Have you tryed to update the BluRay player with new SW / firmwareNo - thumbs down. I have no trouble on myBV7 55 3D?
  • 11-29-2011 3:47 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    There is a software update to cure this problem that occurs with Disney Bluray discs. You local dealer can do this for you by either burning the software upgrade to a disc or via an ethernet connection.
    Opman
  • 11-29-2011 5:51 PM In reply to
    I bought my copy of Cars 2 in Malaysia...
    It was filmed by handycam in a cinema Super Angry
    My B&O: 2009 Catalogue and Pricelist
  • 11-29-2011 6:16 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Mark:
    I'd stick with this player - fewer issues, support for decoding DTS HD etc. Anyway, as the posters say above, it's a sw issue which was updated recently. If you connect your BV7's ethernet port to a wired internet connection, you can update the sw yourself (which is the easiest and quickest approach).
    Before the recent sw update, my BV7 Blu-ray play skipped scenes on some movies and wouldn't play others at all!
  • 11-29-2011 6:40 PM In reply to
    Jonathan:
    What did you expect for 1 dollar..? WinkWhistle (I surely don't hope you've payed full price)
  • 11-29-2011 9:41 PM In reply to
    • Michael
    • Top 500 Contributor
    • Joined on 05-20-2009
    • Glen Waverley, Victoria, Australia
    • Posts 245
    • Gold Member
    Try a different hdmi cableif you have another one lying around. I once had a problem with how blu ray talked to the tv
    Michael.
  • 11-29-2011 10:50 PM In reply to
    Steffen:
    Jonathan:
    lol $3 thankyou! LaughingLaughingLaughing[
    the lady promised me 'no handycam'!!!! Devil
  • 11-30-2011 12:06 AM In reply to
    • Mark
    • Not Ranked
    • Posts 11
    Thanks for the replies.
    The Sony player is in my garage attached to a 50" Plasma Embarrassed (I'm into building race cars in my spare time so I have a full cinema set up in there, TV, BluRay, Surround sound ect - Odd I know!)
    My cables are built into the wall but I will try swapping the one that goes to the Apple TV or X Box to see if that makes a difference.
    I've hated the BluRay player since I bought it. The picture quality is fantastic but it is so slow nad the menu functions are pants with all of the remotes I have had.
    I do already have an ethernet cable connected so I will try this option first (assuming my local store don't say they will "pop round" to fix it - as this is what usually happens everytime I have an issue Smile)
  • 11-30-2011 5:38 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    This issue was first reported by a Scottish Dealer, unfortunately it took a while for Struer to properly understand the problem. The original complaint merely said, -
    "BV7-55 BluRay disney play Disney"!
    I'll get my coat!Embarrassed
  • 11-30-2011 7:21 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Puncher:
    Oh I miss the dry humour from my old NE region :)
  • 11-30-2011 10:21 AM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    Puncher:
    Taxi for Puncher Stick out tongue
  • 11-30-2011 12:39 PM In reply to
    • Mark
    • Not Ranked
    • Posts 11
    With great thanks to my friendly B&O Guru I now have working Car 2 disc!
    For those of you who have the same issue here is what you do:
    How to update the Blu-ray player software
    You can update the software in the Blu-ray player in two ways:
    1. Use a CD R/RW (The software is available from BeoWise – Software & Tools – Service Tool – Service Tool MK II).
    2. Download the software via Ethernet. Ethernet update is the easiest.
    1. CD update
    a. Burn the software on a disc using a standard burning program, for example the program available in Windows.
    b. The TV must be in standby, and there must be no disc in the loader.
    c. Press DVD to activate the Blu-ray player. Wait until the loader slides out. Place the CD in the loader and start playback.
    d. The player will now validate the software; this is informed on the screen. After validation, open the loader and remove the CD.
    e. Press GREEN on Beo5 to save the software. If you use a Beo4, press GREEN twice.
    f. The software is now saved and the screen will briefly be black until the player starts up again.
    2. Ethernet update
    a. Before you switch on the TV, insert an Ethernet cable into socket on the TV.
    c. Press DVD, wait until NO DISC is displayed on the screen and make that sure the loader is closed.
    d. Press DVD setup on your Beo5 to enter the Set Up menu. If you use a Beo4, press YELLOW and 8 at the same time.
    e. Select ADVANCED and press GO.
    f. Select SOFTWARE UPDATE. The Blu-ray player now automatically searches for new software, and the new software will be displayed on the screen.
    g. Press GREEN on Beo5 to start the software update. If you use a Beo4, press GREEN twice.
    Follow the instructions displayed on the screen.
    Happy Days Smile
