Griebel:
Hi Folks,
Would have been a (huge) surprise that the new Beo- 2-way wireless communication with BS5 tool worked properly from the beginning.
I did test it and confirm some of the observations:
- Queue and Play Queue browsing not working Does work!
- Larger cover art not displaying All covers are shown!
- Selection of an album by a long press opens an empty submenu ? after selection of an albums it shows all the tracks
The rest is working, but since the Queue is not working, can only play one track at the time! Complete Albums can be played; long press the album then select play
Is it a software problem or a configuration problem? Since it is working for some of you, I guess it's a BS5/BM5/BEO6 configuration issue.
For those the tool works properly, could you please give us some details on your configuation (eg, BS5/BM5 as audio master etc.)
See above
BM5/BS5 = set as audiomaster, option 0
Internal Harddisk as source of media files
70% WMA lossless, 25% Flac and 5% MP3; embedded covers; file type JPG resolution minimum 500*500 (for 95% maximum not above 600*600)
LAN: Linksys E4200 cat5e or 6 cable to BM5; seperate dedicated LAN sub system;
fixed IP address for BM5 and also for Beo6
