1st March February 2012
Latest post 12-17-2011 8:09 AM by IngvarW. 113 replies.
Alex
- Joined on 04-16-2007
- New York, NY
- Posts 176
Re: Beo6 wifi with Beosound 5
It's available as of today. There's a new service tool available and the updates should have come in over the weekend for the BeoSound 5.
Store Manager
Bang & Olufsen Broadway
927 Broadway
New York, NY 10010
Alex
- New York, NY
- Posts 176
PentaIII:
Can I ask is this only available for Beosound 5 and not Encore?
Correct.
Store Manager
927 Broadway
New York, NY 10010
w5bno123
- Joined on 12-15-2008
- London
- Posts 90
At last, we only saw it two conferences ago!!! They delivered it on time in the end as we were promised by the end of November!!!
Stephan
- Joined on 12-20-2008
- Germany
- Posts 242
Hi there,
can someone tell me/us, which functions are available if you have a Beosound 5 Encore / Beo6 setup?
Best regards
Stephan
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Alex
- New York, NY
- Posts 176
Stephan:
Hi there,
Best regards
Stephan
Nothing new as it is currently only updated for two-way with the BeoSound 5 ... not Encore.
Store Manager
927 Broadway
New York, NY 10010
Electrified
- Joined on 10-05-2009
- Greater Copenhagen, Denmark
- Posts 404
Does anyone know if it works with 802.11n networks or if it only works with G networks?
Also, will this come to the Encore as well at some later date when they have rolled it out for the BM5/BS5 combo?
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Akoro, thanks for the picture. Time for me to order a Beo 6.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
The first product to support the functionality of the new Beo6 firmware is the BeoSound 5 with BeoMaster 5.
The following are the key features implemented so far:-
- Support for two-way sources
- Support for 12 languages
- XML version displayed on Choose products. When you click on the B&O product the version is shown underneath the product image
- Bug fixes including (1) stop sending IR which often causes the battery to go flat (2) Improved interaction on page navigation "arrows"
- Three covers on the first page Playing, Most played and for inspiration!!
- Content browsing
• Browse index – Select first letter of artist or album • Artists – Browse for an artist, view the album and tracks of an artist • Albums – Browse all your albums, view the tracks of an album • Play or Queue selected artists, albums or tracks • Initiate MOTS from tracks
- Status
• Displays a larger cover of what is playing • Artist, album and track information • Status displayed when placed in charger
- Play Queue browsing
• View the Play queue • Skip to track in Play queue • Delete track from Play queue
- Setup menu
• A wireless section has been added • Enter Service Menu (0 0 Select in Setup Menu) • Menu which enables you to check the signal strength • Power menu which enables you to change timeout period to WiFi access point
Other facilities which were actually introduced in Configuration Tool version 4.11 but most people do not appear to have noticed is that you can:-
- Set the IR-output level per zone
- Set IR-output level per macro
- Print list of channel logos
Razlaw
- Illinois
- Posts 1,770
How do you scroll through albums? Buttons or spin the wheel on the Beo 6 like on the Beosound 5?
Alex
- New York, NY
- Posts 176
Razlaw: How do you scroll through albums? Buttons or spin the wheel on the Beo 6 like on the Beosound 5?
Gestures on the screen like an iPhone.
Store Manager
927 Broadway
New York, NY 10010
Razlaw
- Illinois
- Posts 1,770
Wow! Even better than I expected!
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
Roger: Yes, it is available now on the B&O intranet (sw v 2.11a).
Roger
2.11 is not new version!!?
Keith Saunders
- Posts 3,810
mr_anders_son: Roger:
Roger
The Configuration Tool is version 5.12
Keith Saunders
- Posts 3,810
Keith Saunders:
I should have pointed out that what Roger was talking about is the firmware loaded into the Beo6
So, the Beo6 firmware has been updated from version 1.01a to 2.11a
When you download a new configuration to the Beo6 with the Configuration Tool version 5.12 then the new firmware 2.11a is automatically downloaded to the Beo6 prior to your new configuration file.
mjmedlo
- Joined on 06-07-2008
- Arkansas, USA
- Posts 384
My dealer is still telling me its not available...Alex.. Is this for public release yet? Or just beta for stores?
I'm ready for something new that I actually want to buy!
rednik
- Joined on 06-29-2007
- Posts 150
To be fair it has just been released, they may not have even had a chance to try it in store yet, and probably want to play ith and fully understand before releasing to clients.
ECF
- Joined on 03-28-2009
- Posts 17
Can someone please provide a downloadlink?
Best regards,
Erik
IngvarW
- Joined on 10-09-2007
- Sweden
- Posts 108
I just ordered one this evening, and also the BL11, that will be fun.. Brgds Ingvar
Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
Razlaw
- Illinois
- Posts 1,770
Just placed my order for Beo 6.
beolion
- Joined on 10-20-2009
- Posts 245
I am really considering upgrading my Beo5 to Beo6 now.....
There is something about B&O.....
