Latest post 12-17-2011 8:09 AM by IngvarW. 113 replies.
Page 2 of 5 (114 items) < Previous 1 2 3 4 5 Next >
  • 11-29-2011 9:53 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • New York, NY
    • Posts 176
    Re: Beo6 wifi with Beosound 5
    It's available as of today.  There's a new service tool available and the updates should have come in over the weekend for the BeoSound 5.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 11-30-2011 12:20 AM In reply to
    • PentaIII
    • Joined on 04-26-2007
    • Australia
    • Posts 83
    Can I ask is this only available for Beosound 5 and not Encore?
  • 11-30-2011 2:18 AM In reply to
    • Alex
    • New York, NY
    • Posts 176
    PentaIII:
    Correct.
  • 11-30-2011 4:28 AM In reply to
    At last, we only saw it two conferences ago!!! They delivered it on time in the end as we were promised by the end of November!!!
  • 11-30-2011 7:15 AM In reply to
    • akoro
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    It really is here and seems to work fine.
  • 11-30-2011 7:25 AM In reply to
    Hi there,
    can someone tell me/us, which functions are available if you have a Beosound 5 Encore / Beo6 setup?
    Best regards
    Stephan
  • 11-30-2011 7:45 AM In reply to
    Very cool!
    Finally.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 11-30-2011 7:46 AM In reply to
    • Alex
    • New York, NY
    • Posts 176
    Stephan:
    Hi there,
    Best regards
    Stephan
    Nothing new as it is currently only updated for two-way with the BeoSound 5 ... not Encore.
  • 11-30-2011 8:16 AM In reply to
    • Electrified
    • Top 150 Contributor
    • Joined on 10-05-2009
    • Greater Copenhagen, Denmark
    • Posts 404
    Does anyone know if it works with 802.11n networks or if it only works with G networks?
    Also, will this come to the Encore as well at some later date when they have rolled it out for the BM5/BS5 combo?
  • 11-30-2011 9:06 AM In reply to
    Akoro, thanks for the picture. Time for me to order a Beo 6.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 11-30-2011 9:38 AM In reply to
    The first product to support the functionality of the new Beo6 firmware is the BeoSound 5 with BeoMaster 5.
    The following are the key features implemented so far:-
    • Support for two-way sources
    • Support for 12 languages
    • XML version displayed on Choose products. When you click on the B&O product the version is shown underneath the product image
    • Bug fixes including (1) stop sending IR which often causes the battery to go flat (2) Improved interaction on page navigation "arrows"
    • Three covers on the first page Playing, Most played and for inspiration!!
    • Content browsing
      • Browse index – Select first letter of artist or album
      • Artists – Browse for an artist, view the album and tracks of an artist
      • Albums – Browse all your albums, view the tracks of an album
      • Play or Queue selected artists, albums or tracks
      • Initiate MOTS from tracks
    • Status
      • Displays a larger cover of what is playing
      • Artist, album and track information
      • Status displayed when placed in charger
    • Play Queue browsing
      • View the Play queue
      • Skip to track in Play queue
      • Delete track from Play queue
    • Setup menu
      • A wireless section has been added
      • Enter Service Menu (0 0 Select in Setup Menu)
      • Menu which enables you to check the signal strength
      • Power menu which enables you to change timeout period to WiFi access point
    Other facilities which were actually introduced in Configuration Tool version 4.11 but most people do not appear to have noticed is that you can:-
    • Set the IR-output level per zone
    • Set IR-output level per macro
    • Print list of channel logos
    Regards Keith....
  • 11-30-2011 9:39 AM In reply to
    How do you scroll through albums? Buttons or spin the wheel on the Beo 6 like on the Beosound 5?
  • 11-30-2011 11:11 AM In reply to
    • Alex
    • New York, NY
    • Posts 176
    Razlaw:
    Gestures on the screen like an iPhone.
  • 11-30-2011 11:16 AM In reply to
    Wow! Even better than I expected!
  • 11-30-2011 11:26 AM In reply to
    Roger:
    Yes, it is available now on the B&O intranet (sw v 2.11a).
    Roger
    2.11 is not new version!!?
  • 11-30-2011 11:52 AM In reply to
    • Emil
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    Excellent news. Time to order one for me.  Just one question first though. I recall from other threads that the Bs5 would have to be set as audio master in order to use the different iPhone apps out there. Would the same be true for Beo6? I have a Bs9000 that I would like to keep as audio master.
    Inflagrante
  • 11-30-2011 11:56 AM In reply to
    mr_anders_son:
    Roger:
    Roger
    The Configuration Tool is version 5.12
    Regards Keith....
  • 11-30-2011 12:18 PM In reply to
    Keith Saunders:
    I should have pointed out that what Roger was talking about is the firmware loaded into the Beo6
    So, the Beo6 firmware has been updated from version 1.01a to 2.11a
    When you download a new configuration to the Beo6 with the Configuration Tool version 5.12 then the new firmware 2.11a is automatically downloaded to the Beo6 prior to your new configuration file.
    Regards Keith....
  • 11-30-2011 1:43 PM In reply to
    • mjmedlo
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    My dealer is still telling me its not available...
    Alex.. Is this for public release yet? Or just beta for stores?
    I'm ready for something new that I actually want to buy!
  • 11-30-2011 2:27 PM In reply to
    The new version is available to all dealers and it is the full released version
    Regards Keith....
  • 11-30-2011 2:33 PM In reply to
    To be fair it has just been released, they may not have even had a chance to try it in store yet, and probably want to play ith and fully understand before releasing to clients.
    • ECF
    • Not Ranked
    • Joined on 03-28-2009
    • Posts 17
    Can someone please provide a downloadlink?
    Best regards,
    Erik
  • 11-30-2011 3:38 PM In reply to
    I just ordered one this evening, and also the BL11, that will be fun.. Brgds Ingvar
    Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
    Just placed my order for Beo 6.
  • 11-30-2011 3:42 PM In reply to
    I am really considering upgrading my Beo5 to Beo6 now.....
    There is something about B&O.....
