Seanie_230:
The tech spec says the Beemer output it only 2d which is a shame.
Hi!
I think the tech specs are totally confusing:
BV 7-55 3D: Front Projector connection: 1 x HDMI with 2D
BV 7-40 3D: Front Projector connection: 1 x DVI-D
Now take a look in the manual of Beovision 7 ("getting started"):
Connection panels - Beovision 7-55 (page 26): HDMI Out (Projector Out)
Connection panels - Beovision 7-40 (page 28): HDMI Out (Projector Out)
And "Watch 3D television" (at the bottom of page 19):
Projectors:
Not all connected projectors support 3D technology. If a projector connected to the television does not
support 3D, 3D in the 3D DISPLAY menu is greyed out in CINEMA mode.
I would really like to know the correct specs of Beovision 7-55 and 7-40 regarding connected projectors, HDMI and 3D!
Can anybody help me?
Regards
Räuber
