Hello,
I need to control the above mentioned Humax HD-Fox T2 (terrestrial, http://www.humaxdigital.com/uk/products/product_stb_terrestrial_hdfoxt2.aspx ) with my Beovision 3 - 32 (using Beo4) and across my Beolink system (linked BV MX7000/Beo4version ...).
Is there any "equivalent" in any STB-C list which can do the job (main commands at least (on/off, channel up/down, guide etc...)) ?
Thanks in advance.
mauro
Hi Mauro,
the current IC for West Europe should contain boxes that support at least the main functions (if not all).
Best Regards,
- PJ
Hi Pj,
thanks for your support.
More precisely, does anyone know which equivalent Humax STB in the list I need to select beyond any doubt?
For the Humax HD-FOX T2 you can use the Humax CI8100 PVR which is totally compatible.
Regards Keith....
Thanks Keith
