Latest post 11-22-2011 9:43 AM by beolit39. 4 replies.
Page 1 of 1 (5 items)
  • 11-21-2011 4:21 AM
    STB-C LIST (BEOVISION 3 - 32) AND HUMAX HD-FOX T2 - HELP NEEDED
    Hello,
    I need to control the above mentioned Humax HD-Fox T2 (terrestrial, http://www.humaxdigital.com/uk/products/product_stb_terrestrial_hdfoxt2.aspx ) with my Beovision 3 - 32 (using Beo4) and across my Beolink system (linked BV MX7000/Beo4version ...).
    Is there any "equivalent" in any STB-C list which can do the job (main commands at least (on/off, channel up/down, guide etc...)) ?
    Thanks in advance.
    mauro
  • 11-21-2011 5:36 AM In reply to
    Re: STB-C LIST (BEOVISION 3 - 32) AND HUMAX HD-FOX T2 - HELP NEEDED
    Hi Mauro,
    the current IC for West Europe should contain boxes that support at least the main functions (if not all).
    Best Regards,
    - PJ
  • 11-21-2011 6:41 AM In reply to
    Hi Pj,
    thanks for your support.
    More precisely, does anyone know which equivalent Humax STB in the list I need to select beyond any doubt?
    mauro
  • 11-21-2011 10:02 AM In reply to
    For the Humax HD-FOX T2 you can use the Humax CI8100 PVR which is totally compatible.
    Regards Keith....
  • 11-22-2011 9:43 AM In reply to
    Thanks Keith
