Latest post 11-19-2011 10:40 AM by Fakyata. 5 replies.
Page 1 of 1 (6 items)
  • 11-19-2011 4:23 AM
    • Fakyata
    • Not Ranked
    • Joined on 11-12-2011
    • Leeds, WY
    • Posts 17
    Not working BeoMaster 6000
    Hi,  i get 1 sapre BM6000 unfortunately appear to be faulty , well its turning on for a 1-2 sec then going off with little tick like sound, however it stays on for about 10 minuts when i put it straight away into clock mode
    any ideas what could be wrong with it ?
    Beomaster 4400, 2 Beomaster 6000, Beocord 8004, Beocord 8002, Beolink 1000, 3x Beo4, Terminal 6000, Beovision LX6000, Beovision AV9000, Pair of Beovox s75, Beovision Avant 32 DVD, Beovox Redline 60.2, Beogram 1100, Beovision MX1500, Beovision 3, B&O Cabinet 4068
    Cabinet 4068
  • 11-19-2011 4:51 AM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Re: Not working BeoMaster 6000
    My guess is bad quiescent current because of bad trimmers in the amp section...
    The usual!
    Jacques
  • 11-19-2011 5:42 AM In reply to
    Is the BeoMaster getting hot before it is switching off? In that case it could indeed be the potentiometers in the amp section!
  • 11-19-2011 5:59 AM In reply to
    • Fakyata
    • Not Ranked
    • Leeds, WY
    • Posts 17
    i dont think its getting hot as he turn off after 2 sec of turning on , and stays in standby mode ... is it easy to fix ?
    Cabinet 4068
  • 11-19-2011 9:06 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    It is an easy fix—I just did mine—provided you know a few basic notions about electronics.
    The Beomaster 6000 is easy to open and access to modules is easy as well. You shouldn't have any problems finding the necessary service manual which by the way is available on this site to gold members which I'm now proudly one!
    Do you know what a quiescent (idle) current is? Can you identify the different components?
    If so, we can help, and you'll find here the right people for the job!
    Jacques
  • 11-19-2011 10:40 AM In reply to
    • Fakyata
    • Not Ranked
    • Leeds, WY
    • Posts 17
    to be honest im not really into fixing electornics by myself , however if i get proper instructions i can do almost everything :p or it might be just better to let somebody else to fix it ?:)
    Cabinet 4068
