Latest post 11-21-2011 7:03 PM by Chris. 2 replies.
Page 1 of 1 (3 items)
  • 11-16-2011 8:42 PM
    • Chris
    • Top 500 Contributor
    • Joined on 05-09-2010
    • Last of the Summer Wine Country, Yorkshire, UK
    • Posts 195
    • Gold Member
    Is it possible to use Beo4 to control non-B+O equipment using the itrans translator or similar?
    Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
  • 11-17-2011 3:42 AM In reply to
    Re: Is it possible to use Beo4 to control non-B+O equipment using the itrans translator or similar?
    The short answer is "YES"
    The long answer is that there are several products on the market which can achieve your objective.
    The Product you will see most often quoted is Lintronics HERE who are also an offical B&O business partner.
    Other products such as IRtrans apparently work well, but I have never had a need to use this product, but I know that many members do use it without problems.
    Regards Keith....
  • 11-21-2011 7:03 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Re: Is it possible to use Beo4 to control non-B O equipment using the itrans translator or similar?
    Keith, thank you for all the help. Do you know of any other products than lintronic or itrans that would work?
