Latest post 11-15-2011 11:09 AM by rfc1. 4 replies.
Page 1 of 1 (5 items)
  • 11-15-2011 7:18 AM
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    Beosound 4 sd card
    Can anyone confirm excactly the type and size of sd card that i can use in my beosound 4 ?
    Thanks Sandy
  • 11-15-2011 7:29 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Beosound 4 sd card
    Depends on software version - early one 2gb, after sw update or sw + eprom update 8gb shdc
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-15-2011 7:41 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Just tried a 4gb sdhc in mine its no good. Is the upgrade possible on the 2gb versions?
    Sandy
  • 11-15-2011 8:48 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Yes, later 2gb units only need swoftware upgrading, earlier units need a chip upgrade as well - the type of upgrade is dictated by the serial number, your dealer should be able to sort it out - sw upgrade takes about 15 mins
  • 11-15-2011 11:09 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    stotty1111:
    Thanks mate, called B&O Glasgow and it needs both done, someone is coming tommorow to do it at my home, 1st time i have used the B&O shop in Glasgow and very impressed with the service.!
    Sandy
