Yes, later 2gb units only need swoftware upgrading, earlier units need a chip upgrade as well - the type of upgrade is dictated by the serial number, your dealer should be able to sort it out - sw upgrade takes about 15 mins
I always try to operate using/following the KISS principle -- Keep it simple stupid!
