Latest post 12-02-2011 8:54 PM by Søren Hammer. 3 replies.
Page 1 of 1 (4 items)
  • 11-07-2011 4:01 PM
    Beolink1000 paired with beomaster 5500 help!!!
    Hi my Beoworld friends:
    Here Iam asking for your expert help and guidance, I just recently found a beolink1000 remote and I would like to know if it's possible to do the basic functions with the beomaster 5500, do I need some kind of special codes or do I just point and use? I've tried that but nothing works with it, I do have the MCP 5500 that came with the system, but it's kind of bulky and would like to use the other remote instead...
    Thank you for your help
  • 11-07-2011 4:20 PM In reply to
    Re: Beolink1000 paired with beomaster 5500 help!!!
    It doesn't need anything special and works great with a BM5500.
    Do you have a reason to be convinced that the Beolink 1000 actually transmits anything? Try looking at the sending end with a mobile phone camera while pressing a button...
    -mika
  • 12-02-2011 8:25 PM In reply to
    • pepps
    • Not Ranked
    • Joined on 11-09-2009
    • Faversham, Kent
    • Posts 51
    • Silver Member
    I use the same combo. Sometimes I have to press the AV button on the Beolink 1000 mid-use to reconnect the two.
  • 12-02-2011 8:54 PM In reply to
    Beolink 1000 worked great with my 5500 system, almost all functions are accable with the BL1000 Smile
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
