Latest post 11-08-2011 2:49 AM by HVD. 5 replies.
Page 1 of 1 (6 items)
  • 11-06-2011 1:41 PM
    Album Covers naming Bug
    When you have different artist with the same album name.... bijv greatest hits,very best of,Hit Singles etc etc
    Then everything is mixed up,all the covers are wrong.
    is this a bug?
    Is B&O aware of this Sw problem.
  • 11-06-2011 4:26 PM In reply to
    Re: Album Covers naming Bug
    Have the same issue. Guess it's a bug.
  • 11-07-2011 2:53 AM In reply to
    • HVD
    • Not Ranked
    • Joined on 02-21-2009
    • Posts 33
    That is not a bug. It actually is a change in the softeware more than a year ago. If you have an album containing many diffrent artist, it sorted them different under "album view". Now it sorts "album" only after album name.
    I personally think that is better and there was a lot of complaints initally about this as fare as I recall.
    Solution: don´t name the albums the same ie "greatest hits" but maybe "artist greatest hits".
    BS5/BM5, BL3, AVANT 32", BL8000
  • 11-07-2011 2:57 AM In reply to
    • HVD
    • Not Ranked
    • Posts 33
    I think you are not using "album view" with the covers displayed on the right side of display for selection? (I have danish language selected, so it might not be called "album view" when you can see the covers on the right side.
  • 11-07-2011 10:19 AM In reply to
    Song - Angie
    Artist - The Rolling Stones
    Album - The Greatest Hits
    That's the way it should be (imho)
    If I did it your way the artist showed 2 times when albums is selected
               Cover
               The Rolling Stones
               The Rolling Stones Greatest Hits
  • 11-08-2011 2:49 AM In reply to
    • HVD
    • Not Ranked
    • Posts 33
    I don't know how you correct the names on the albums, but i use BeoPlayer and correct everything in that. Taht way there is no problems with the way I name and sort the albums.
    I have seen a lot of similar problems with other users that do not use BP, but different software, which migt end up with a different tagging?
    Anybody that has same problems?
