Hi
Some cleaning and wire managing was necessary in my living room. I unplugged my Beosound 9000 and put it flat on a table. It is mounted vertically on a stand. It has been working very well. I put it back on the stand after the cleaning and ...
It started playing. I changed the CD and the CD mechanism/tray just got stuck. I turned off the unit and turned it back on .. Nothing it would not even turn on.. I read the manual and tried to center the mechanism thinking that maybe it had moved. I couldn't find the little tool so I used a flat screwdriver...
The arrows were already pointing up but I moved them around and up... Ok...
Turn unit on, It seems to work, changes CD, etc...
Mount it back on the stand... Unit play CD 1.. Good.. Trying to change to CD2 .. CD trays is stuck, between CD 1 and 2, closer to 1 as if trying to move and unable to, then after a minute or 2... the tray mechnism simply falls to CD position 6 where it plays nothing .. . After a a long while and numerous clicking sounds. The whole unit turns off and won't play anything...,
Glass door will not open even when I press the button. CDs don't play when I pres their buttons on the unit itself..
If I leave the unit for say 10 minutes and try to turn it on, some lights come on but no LED display an it plays nothing not even radio ...
What can I do? I am technically proficient, although I know nothing about the inside of a B&O, yet, I would not mind getting inside the unit.. Or is it a dealer (read expensive) repair job?
Let me know.. Very weird...
