Hi colleagues,
Unfortunately one of the Beolab 4000 switches continuously on and off. Presumably the main board is defect so I have ordered a new one. Can anybody tell me how to open the speaker?
BR
Pull the grill off, then you have to remove the front plate via some small torx screws.
The rest is self-explanatory!
Good luck!
here
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Mexico: here
Great! THANK YOU
It is done! I bought a new main PCB from B&O and replaced the old one. That solved the annyoing power switching. Only EUR 110,-.
