Latest post 12-01-2011 5:15 AM by stampfki. 4 replies.
Page 1 of 1 (5 items)
  • 11-04-2011 9:03 AM
    Disassembling Beolab 4000
    Hi colleagues,
    Unfortunately one of the Beolab 4000 switches continuously on and off. Presumably the main board is defect so I have ordered a new one. Can anybody tell me how to open the speaker?
    BR
  • 11-04-2011 9:31 AM In reply to
    Re: Disassembling Beolab 4000
    Pull the grill off, then you have to remove the front plate via some small torx screws.
    The rest is self-explanatory!
    Good luck!
  • 11-05-2011 8:14 PM In reply to
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 11-06-2011 3:45 AM In reply to
    Søren Mexico:
    Great! THANK YOU
  • 12-01-2011 5:15 AM In reply to
    It is done! I bought a new main PCB from B&O and replaced the old one. That solved the annyoing power switching. Only EUR 110,-.
