Latest post 10-27-2011 1:43 PM by elephant. 1 replies.
Page 1 of 1 (2 items)
  • 10-27-2011 5:35 AM
    ATV2 and Beovision 6 (DVI)
    Hi.
    I have a ATV2 and a Beovision 6 (DVI only). Connected with HDMI to DVI, and from optics to R/L (Converter) My ATV2 i running software version 4.3. No problem.
    When I upgrade to 4.4 there is no picture on my BV6? Connecting PC monitor to ATV2 - Works. Connecting PC to BV6 - Works.
    So i ended up downgrading ATV2 to version 4.3. Everything works again!!
    Annyone experienced this, and solved it?
    Regards
    Klaus
  • 10-27-2011 1:43 PM In reply to
    Re: ATV2 and Beovision 6 (DVI)
    Two thoughts ...
    4.4 seems to have been buggy and is already updated to 4.4.2 ... perhaps try again ?
    And part of the 4.4.x upgrade has been to add a range of resolution and scan rate options to the ATV2 ... perhaps the mismatch is happening at that level ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
