Latest post 10-29-2011 8:32 PM by Vienna. 5 replies.
Page 1 of 1 (6 items)
  • 10-26-2011 2:42 PM
    Beocenter 2, Beoport and Beomedia...
    Hi folks!
    Again... I am posting on the forum to be helped as I am out of solution... :)
    Here is my problem. At first I had a Beocenter 2 connected to a Beoport which was connected to my PC.
    Everything was running well and I was able to get my music from the computer to the Beocenter 2 using the NMUSIC functionnality. Everything was perfectly working. I must precise the speakers are connected to the socket unit of the Beocenter 2 and not to the Beoport. I do not need to have the sound of the PC to the speakers, so if fits my needs.
    After having played a lot, I wanted to setup a NMUSIC system without using my computer. So I bought a second hand Beomedia 1. I configure it, copy my music on it, plug a headset to the line output just under the ML jack and everything was working : I could hear the music :) So I wanted to use it in combination with my Beocenter 2. What I did for the plugin was :
    - Connect the ML cable from the socket unit of the Beocenter 2 to the Beomedia
    - no other connection (network)
    I do not plug a jack cable as (again...) I thought the ML cable was for audio and video AND the only audio output I had on the Beocenter 2 was the jack on the master unit... not good. Each time I select NMUSIC on the remote control or directly on the LIST menu of the Beocenter 2, it does not work.
    I thought the Beomedia 1 was the same thing as my PC + Beoport, but it seems not...
    So here is my 2 problem :
    1. On which connector should I plug the jack of the Beomedia 1? in the socket unit I suppose, but there is no line IN...
    2. Why the Beomedia 1 is not NMUSIC working with the Beocenter 2 ?
    Thanks a lot,
    Sergio
  • 10-27-2011 6:47 PM In reply to
    Re: Beocenter 2, Beoport and Beomedia...
    after spent time reading older post and digging on Internet, it seems that the Beomedia 1 can not be a master audio and thus can not act as a PC + Beoport... is this correct?
    sergio
  • 10-27-2011 6:59 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    sergi0:
    The BeoMedia 1 was, as far as I remember, always intended for being connected to a TV
    (=video-master).
  • 10-28-2011 1:49 AM In reply to
    • hfat
    • Top 500 Contributor
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    The installations guide for BM1 says:
          Audio master
                                                To be able to distribute N.MUSIC and N.RADIO from BeoMedia 1 to audio and
                                                video link rooms, an N.MUSIC / N.RADIO compatible audio master is required, i.e.:
                                                BeoSound 3000 / 3200 / 9000 / BeoCenter 2 / BeoCenter 1 / BeoSound 4.
    So your BeoCenter 2 needs to be configured as audio master. Maybe you need a SW update of Beocenter 2 to support N.Music. The same was true for BS300.
    hfat
  • 10-29-2011 12:15 PM In reply to
    Hi hfat,
    It is already NMUSIC compatible because it is working with Beoport. I try to find a setup in the Beocenter 2 in order to configure it as a audio master, but there was nothing. I download the latest guide and nothing here neither...
    sergio
  • 10-29-2011 8:32 PM In reply to
    • Vienna
    • Posts 712
    sergi0:
    If a BeoCenter 2 is set to "A.OPT" "0" or "1" or "2" it is an AUDIO MASTER
    - if you set it to "A.OPT" "5" or "6" (to use a BeoCenter 2 as a secondary
    Audiosystem in a MasterLink system) it's not any longer an Audio Master.
    Set your BC 2 to "A.OPT" "2"
    The BM1 was always intended to be a part of a TV setup - for some older
    TVs an external IR receiver was necessary ...
