Hi folks!
Again... I am posting on the forum to be helped as I am out of solution... :)
Here is my problem. At first I had a Beocenter 2 connected to a Beoport which was connected to my PC.
Everything was running well and I was able to get my music from the computer to the Beocenter 2 using the NMUSIC functionnality. Everything was perfectly working. I must precise the speakers are connected to the socket unit of the Beocenter 2 and not to the Beoport. I do not need to have the sound of the PC to the speakers, so if fits my needs.
After having played a lot, I wanted to setup a NMUSIC system without using my computer. So I bought a second hand Beomedia 1. I configure it, copy my music on it, plug a headset to the line output just under the ML jack and everything was working : I could hear the music :) So I wanted to use it in combination with my Beocenter 2. What I did for the plugin was :
- Connect the ML cable from the socket unit of the Beocenter 2 to the Beomedia
- no other connection (network)
I do not plug a jack cable as (again...) I thought the ML cable was for audio and video AND the only audio output I had on the Beocenter 2 was the jack on the master unit... not good. Each time I select NMUSIC on the remote control or directly on the LIST menu of the Beocenter 2, it does not work.
I thought the Beomedia 1 was the same thing as my PC + Beoport, but it seems not...
So here is my 2 problem :
1. On which connector should I plug the jack of the Beomedia 1? in the socket unit I suppose, but there is no line IN...
2. Why the Beomedia 1 is not NMUSIC working with the Beocenter 2 ?
Thanks a lot,
Sergio
