Thanks for the reply and suggestion, I thought about that and have tried it, but no matter what combination I have tried my screen just displays Format 3 on the display. Not sure if I am missing something...
What are the available options for the Format command? I assume just Format+n as you mentioned where n=1, 2, 3... depending on the available options the system or display supports.
Any one know what options the BV4 -50 MKII and BeoSystem 1 does support in regards to available formats?
So if the soft command FORMAT+n on my Beo4 isn't work where do that leave me? Any other options or will have to have a BeoTech come out in order to resolve the issue.
BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
