Latest post 02-19-2012 3:08 AM by beoandy. 27 replies.
Page 1 of 2 (28 items) 1 2 Next >
  • 10-21-2011 3:34 PM
    REG 2 command of Beo4 for Beo5/6 remote
    Hi Folks,
    I'm looking for an XML for the REG 2 command of my special Beo4 remote to program it in the Beo5/6 remotes.
    Now you may wonder what the REG 2 command does. Well, we use it to make the DVD (not the blu-ray) players of BeoVision 7 TVs region free for customers who ask for.
    Tried to capture the command with the Lintronic TT455-RT-238 signal converter, but it didn't work, which is kind of surprising and somewhat disappointing for a product which is supposed to be universal and which gets the commands of any remote... but the B&O ones.
    Any clues to get the REG 2 command into the Beo5/6?
  • 10-22-2011 10:02 AM In reply to
    Re: REG 2 command of Beo4 for Beo5/6 remote
    Unfortuneately, like most IR receivers and converters, they use standard receiver diodes which generally only work with carrier frequencies between 20 and 80 Khz. B&O uses 455 Khz, hence why the Lintronics box could not capture the code. Also, because most capture devices need to count the carrier pulses means you need a fast micro proccessor in your capture device.
    All is not lost, if we can establish the command HEX code, then a command can be added.
    The best way to establish the HEX code is to put an PC type oscilloscope on the IR receiver in a B&O product and capture the screen shot which can then be decoded.
    Regards Keith....
  • 10-22-2011 10:17 AM In reply to
    You should be able to receive B&O commands with the TT455-RT-238, if you connect an external receiver to it. Lintronic sells one and according to the pictures on their web site, it's a regular issue B&O hockey puck with perhaps a custom cable.
    (I've never used these products myself, so don't really know much more than this.)
    -mika
  • 10-22-2011 10:35 AM In reply to
    tournedos:
    Yes, you are correct Mika, you can use an external PUC. I was talking about the internal IR receiver.
    Regards Keith....
  • 10-23-2011 1:51 PM In reply to
    Right. Lintronic is selling a BO-sensitive IR receiver, but I was told by them that it doesn't allow to capture the signal.
  • 10-23-2011 1:53 PM In reply to
    Thanks Keith for your clear explanations. Well, I unfortunately don't have a PC oscilloscope. Just have the Lintronic device, which I thought would work.
  • 10-23-2011 3:10 PM In reply to
    Griebel:
    Yes, I would expect that to be true because of the reason I highlighted earlier, the need for a fast micro processor to count the carrier pulses.
    At 455Khz the pulse period would be one divided by 455000 which gives you a period of 2.1 micro seconds per pulse period, that is why the only real way is with an Oscilloscope.
    Regards Keith....
  • 10-24-2011 10:30 AM In reply to
    • hfat
    • Top 500 Contributor
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    It's dependig which type of Lintronic box you have. The version 5 is able to capture B&O signal without external IR-Eye. HW6 needs an IR-Eye. You could try to use the log application of the lintronic configurator when capturing the signal and post the result. Maybe there's a way to analyze the command format of the REG 2 command.
    hfat
  • 10-24-2011 2:48 PM In reply to
    Well, if hfat statement is correct about the version 5 box AND you have a version 5 Lintronic box, then we should be able to work out the hEX code of the command.
    Regards Keith....
  • 10-25-2011 1:03 AM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    If someone tells me how to send an REG2 command, I'll try to capture it.
    hfat
  • 10-25-2011 4:24 AM In reply to
    I have the latest version of the Lintronic software/device, but it doesn't capture any BO remote signal.
  • 10-25-2011 5:30 AM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    The latest version is HW6, which needs an extra IR-Eye to capture B&O signals
    hfat
  • 10-25-2011 1:43 PM In reply to
    Well, as far as BO remotes are concerned, this new update seems like a downgrade.
  • 10-25-2011 2:16 PM In reply to
    Griebel:
    I went through the Lintronic web site a year or two ago, and as far as I recall back then they were selling a cheaper external B&O receiver, which to me seemed nothing but a TSOP7000 three-pin IR receiver IC hanging off a length of cable and a 3.5mm plug. This chip seems to be discontinued or at least has availability problems, which might also explain why Lintronic in the latest version has omitted the integrated B&O receiver (it's a lot of circuitry to implement with discrete components) and only offers the solution with an external B&O hockey puck.
    However, receiving (possibly only predefined) commands and capturing them are two different things, and that will be a software issue. Earlier you said that according to Lintronic, the box won't allow capturing B&O commands - are you sure that the terms are right here and everybody understands what others are talking? Obviously the box can receive B&O commands, either with an internal or external receiver depending on the version.
    It may only handle known commands, and this "REG 2" whatever is obviously a "secret" command that can only be sent by special service remotes.
    I have a TSOP7000 connected to a small microcontroller board on my desk as I write, and could also capture the command, but alas, no remote...
    -mika
  • 10-26-2011 3:44 PM In reply to
    Yes, I'm speaking about capturing. Actually, M. Lintronic confirmed that capturing BO remote commands is not possible, and he couldn't be sure that the special IR eye would be able to do the job, although of course it receives commands.
    I have the special remote, but no capturing device. Too bad! It's the only special remote left for the dealers in the whole parisian area. I think I'll put it in a safe :-)
  • 10-26-2011 5:35 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    I can try to capture that with my IRTrans module (it captures B&O signals, then, Keith, you can try to convert IRTrans to XML, as usual!) : I'm in Paris... Let's try to do that next week!
  • 10-26-2011 6:15 PM In reply to
    This is a long shot and may not be practical, but Philips ProntoNG remotes (& Marantz Equivalents)  can learn B&O codes so if you can find someone nearby who has the remote it may be worth a try. It will need to be the ProntoNG versions not the older Pronto models. NG versions are:- RU950, RU960, RU980, RU990, [or US versions TSU3000, TSU3500, TSU7000, TSU7500] or Marantz RC5400 & RC9500.
    I know they can learn the B&O remotes because I have the RC9500 and have owned the RU950 & RU980 which all learn & then control B&O, but I'm not sure how you would then extract the info you need from the resulting PCF file. I think you can export the file to a CCF which I think Keith knows about. You certainly can view and copy and paste the learned codes onto a word doc or spread sheet. For example the learned CD button from my BEO4 shows this :-
    7000 0009 0000 000D 0003 0017 0005 0005 0001 0005 0004 0004 0004 0004 0004 0004 0004 0003 0004 0005 0004 0003 0005 0004 0003 0005 0002 0005 0010 0994
    The learned RADIO code shows this:
    7000 0009 0000 000D 0003 0017 0005 0005 0001 0005 0004 0004 0004 0004 0004 0004 0004 0003 0004 0005 0004 0004 0004 0004 0004 0003 0002 0005 0010 0994
    and the learned A.TAPE code shows this:
    7000 0009 0000 000D 0003 0017 0005 0005 0001 0005 0004 0004 0004 0004 0004 0004 0004 0003 0004 0005 0004 0003 0005 0004 0004 0003 0002 0005 0010 0994
    Keith will be able to tell you if that means anything and shows the type of data he needs. If this does look correct, it confirms the Pronto learns correctly and you can then find someone with one to help you or purchase second hand for your self and learn from your special Beo4. If my codes don't look correct, the Pronto make be "Faking" B&O codes just enough to contol B&O but not enough for your purpose.
    I hope that helps a little (or even a lot)
    Stoobie
  • 10-28-2011 7:55 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    I've sent a mail to Griebel as we are both in Paris and I can quickly capture the code with my IRTrans box, but he didn't reply... Wait and see!
  • 11-21-2011 3:26 AM In reply to
    Marc kindly arranged to capture the REG1 and REG2 codes with his IRtrans module and sent them to me.
    I can confirm that I have converted then with the following results:-
    • REG1 has a HEX command code of 58 which is also used for the "Panel Off" command
    • REG2 has a HEX command code of FC
    The Beo4/5/6 IR protocol has the capacity for 255 commands per device. It also has the capacity for 255 devices in theory.
    Only five (5) device codes are in regular use in the typical system.
    Regards Keith....
  • 12-22-2011 3:28 PM In reply to
    Keith Saunders:
    In the Beo5/6 Configuration Tool, I could find the "Panel Off" command but not the "FC" command. Where is it? Would  you be willing to create and post an XML with a macro for making the BeoCenter 2 region-free, Keith?
  • 12-23-2011 9:53 AM In reply to
    I have sent you an E-Mail, but it was rejected because your e-mail address is apparently no longer valid. Please provide your new e-mail address.
    Regards Keith....
  • 12-23-2011 2:02 PM In reply to
    Thanks, Keith. My email is jcragen@mac.com.
  • 12-27-2011 5:07 AM In reply to
    • Thomas
    • Joined on 04-16-2007
    • Norway
    • Posts 85
    Hi Keith
    Would it be to much trouble to make an xml for an 32 avant DVD mkII with the Reg command to make the Dvd region free ?
    my emai: tho-las@online.no
    All the best
    Thomas
    7-40 Mk3, Beo5/Beo4, Avant32DVD, BS3K, PentaIII, BL4K, BL Active w/BL2500, Avant28CTV,Beoport, AppleTV, 2xBC6K
  • 12-28-2011 11:57 AM In reply to
    beojeff:
    I have sent you an e-mail and updated your e-mail address on Beoworld..
    Regards Keith....
  • 02-10-2012 9:04 AM In reply to
    • Thomas
    • Norway
    • Posts 85
    Keith was kind enough to provide me with the XML file for the Reg commands, and instructions how to use it, it all went very well and now my Avant is also Region free :-)
    All the best
    Thomas
