Latest post 10-22-2011 4:10 PM by Holmfirth. 4 replies.
Page 1 of 1 (5 items)
  • 10-17-2011 11:53 PM
    Beomaster 2000 with missing L Phono Channel
    Hello B&O Worldlings.
    I'm the original owner of a Beomaster 2000 with matching Beogram 2000 turntable.  The left channel on the phono input had been going weak and has now gone completely.
    Where and what should I look for?
    The L channel works fine with the radio and Aux inputs.
    Holmfirth.
    Filed under:
  • 10-20-2011 1:41 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2000 with missing L Phono Channel
    Welcome to Beoworld !
    Beocenter 2000 has a built-in turntable and it does not match any of the Beogram 2000 models designwise
    so I believe that is not what you are talking about.
    Is it a Beosystem 2000 you have (Beomaster 2000 + Beocord 2000 etc.) ?
  • 10-20-2011 3:40 PM In reply to
    Yes, Martin.  You are quite correct, I have mis-labeled my Beomaster 2000 as a Beocenter 2000.  Not a very good start is it?
    Thinking that the DIN cord could have failed?
    Holmfirth
  • 10-20-2011 3:53 PM In reply to
    • Dillen
    • Posts 5,008
    It wouldn't be a first.
    - Or the cartridge.
  • 10-22-2011 4:10 PM In reply to
    Thanks for the response, it was the cartridge.
    I was able to locate my decent MMC3 and we are back in business.
    I have quite a collection of failed cartridges now.
    Walter.
